Author Topic: MSD 6AL  (Read 3757 times)
Online Zedman240
  • Dimitri V
  • Donating Member
  • Registered User
  • 'I hate it when people spell my name rong'
Re: MSD 6AL
« Reply #15 on: August 18, 2010, 06:24:33 PM »
Cover might inhibit cooling air to it. Is it possible to fit it behind the firewall like behind the glovebox etc? I think anything electronic should be kept as cool as possible. With the Wolf ECU they do highly recommend you mount it in the cabin and not under the bonnet; but that's something different.
HS30-00121 'early girl' .........Me love zeds long time..
RS30-15224 'older girl" in progress!
Breaks - Something that fails.
Brakes - Stop your car.
There - in  or  at  that  place  ( opposed  to  here).
Their - of, belonging to, made by, or done by them
Offline luvemfast
  • Simon
  • Donating Member
  • Registered User
Re: MSD 6AL
« Reply #16 on: August 18, 2010, 08:34:01 PM »
Wouldn't you also want it as close as practical to the dizzy?
Offline Gareth. J.
  • Donating Member
  • Registered User
Re: MSD 6AL
« Reply #17 on: August 19, 2010, 07:22:08 AM »
that was my thought also, shorter cable run means less voltage drop... Msd say 5000ohms of resistance means 5000volts less at the plug
Offline d3c0y
  • Garage San Maru
  • Registered User
Re: MSD 6AL
« Reply #18 on: August 23, 2010, 03:34:08 PM »
The MSD unit itself doesnt make the spark - the coil still does that, hence why the coil is next to the dizzy.
You should mount the box inside the cabin. They dont like moisture or heat as stated.
There is room under the dash or on the passenger's kick pannel.
Not putting miles on your Ferrari is like not having sex with your girlfriend so she'll be more desirable to her next boyfriend.
'73 240Z L24 44 Mikunis 5spd
'90 300ZX TT 2 Seater Targa 5spd
'01 Yamaha YZF-R6
'11 Kawasaki KX-F250 EFI
Offline Six_Shooter
  • Registered User
  • Canuckian
Re: MSD 6AL
« Reply #19 on: August 23, 2010, 07:00:09 PM »
The MSD 6AL does fine in both moisture and high heat conditions.
As long as it's not in a direct stream of water or mounted to the exhaust manifold it will live a long life under the hood.
Unless the weather patterns have changed since I was Oz, it isn much drier, even the south east and eastern states, than up here in Canada, and I don't see many problems with under hood mounted MSD boxes, I think I've seen one or two, and it was more to do a bad batch of MSD boxes than mounting location, since there were a couple mounted inside that also failed.
Offline Ben
  • Registered User
Re: MSD 6AL
« Reply #20 on: September 01, 2010, 10:25:18 PM »
My 6AL is under the passenger seat. You can hear it happily buzzing away at idle...
I'll probably put it on the kick panel to make it a bit neater.
Ben
L28ET 1973 240Z
FJ20ET 1983 DR30 Skyline RS-X
RB25DET 1996 WGNC34 Stagea RSFV
1975 1200 ute for sale, $3500 w/A14, $2500 without
Offline Gareth. J.
  • Donating Member
  • Registered User
Re: MSD 6AL
« Reply #21 on: September 02, 2010, 07:34:50 AM »
My 6AL-2 is mounted between the battery and passenger strut tower, MSD said that would be fine and so far so good!
Offline luvemfast
  • Simon
  • Donating Member
  • Registered User
Re: MSD 6AL
« Reply #22 on: September 02, 2010, 07:40:24 AM »
It obviously helped you last weekend Gareth, to break the 2min mark at the Island.
Did you actually notice a gain? If so how much, and where? (more torque, revs etc)
How much $$?
Offline Gareth. J.
  • Donating Member
  • Registered User
Re: MSD 6AL
« Reply #23 on: September 02, 2010, 08:34:46 AM »
It was $400. It's heaps smoother to drive, more responsive, better economy (not that I care about that). After starting stone cold it'll idle at 750rpm with no chokes straight away. There's also the rev limiter set for 7000rpm, which is handy and the launch control but thats not hooked up....... yet  ;D
Offline luvemfast
  • Simon
  • Donating Member
  • Registered User
Re: MSD 6AL
« Reply #24 on: September 03, 2010, 07:51:46 AM »
Got an opportunity to get one of these, 6 months old for $200.
Do you think it would be worthwhile?
Offline Gareth. J.
  • Donating Member
  • Registered User
Re: MSD 6AL
« Reply #25 on: September 03, 2010, 07:59:54 AM »
Sounds like a great deal to me if it's the 6al-2.   The 6al is an older version and is readily available for around $200
Offline luvemfast
  • Simon
  • Donating Member
  • Registered User
Re: MSD 6AL
« Reply #26 on: September 03, 2010, 09:00:27 AM »
Good point, it may have been a 6AL, whats the difference to the 6AL-2?
Online NZeder
  • Registered User
    • http://nzeder.net
Re: MSD 6AL
« Reply #27 on: September 03, 2010, 09:09:35 AM »
6al = analogue aka old tech. 6al-2 digital much newer tech :)
http://www.msdignition.com/product.aspx?id=5813
« Last Edit: September 03, 2010, 09:11:44 AM by NZeder »
76 RS30 260z 改RB26 N/A 霞
Previous
70 HS30-00016 240z
72 HS30 240z L型 2.8
71 HS30 240z L型改3.2
79 HS130 280zx
82 HS130 280zx T top
2x 73 KP710 160JSSS
74 KB210 120Y Coupe
71 510 1600 Deluxe
Offline DatPilot
  • I love Nissan, its like giant Lego
  • Registered User
  • you are a goose
Re: MSD 6AL
« Reply #28 on: September 03, 2010, 10:51:53 AM »
Doesnt the 6AL have a couple of 'chips' that you plug in to set rev limits
then the 6AL-2 have a dial (well 2 dials) for revs??
ebay USA have a few different options, the dollar is pretty good too! (91 cents)
Cheapest in OZ I could find was $325
Super Karate monkey death car
Offline Six_Shooter
  • Registered User
  • Canuckian
Re: MSD 6AL
« Reply #29 on: September 03, 2010, 12:49:58 PM »
The 6AL has a single pill to plug in to set the rev limit. You can get adaptors, like the "2 step" and "3 step" to set multiple rev limits. If you're handy with some sodler and resistors, and potentiometers you can make your own adjustable "pills".
I have a 6AL in the attic, I'm not sure where it came from, and not sure what I'm going to do with it, since I don't own a vehcile that has a dizzy anymore.
