Author Topic: What's the difference between 240z Carbys and 260z Carbys?  (Read 2723 times)
Offline stevo_gj
  • Global Moderator
  • Registered User
  • Steve
« on: June 07, 2010, 07:31:38 PM »
Hey guys,
We get this question often enough. Might help if we centralized a bit of information on it.
240z carby's AKA Round Tops:
Made by Hitachi, they were a Jap licensed copy of British SUs. They came in 3 and 4 screw variations, which refers to the number of screws holding down the dome. They are good carbs and are easy to tune and work on. I put a set on my 260z.
260z carby's AKA Flat Tops:
Also made by Hitachi, they were still based on the British SU but were much more modified to pass emissions regulations. 260z carby's are known for being difficult to work on, poor for performance and generally ugly. It is very common practise for Z owners to replace them with British SUs or 240z Hitachi SUs.
Feel free to add more info guys - I'll update the main post with it.
Edit: Here is a good website with a lot of relevant information: http://www.zparts.com/zptech/tech_tips/izccposts/su_differences.htm
« Last Edit: July 06, 2010, 09:46:46 PM by stevo_gj »
Offline sexual_sushi
  • Donating Member
  • Registered User
    • 26TZD Ownership history (WIP)
Re: What's the difference between 240z Carbys and 260z Carbys?
« Reply #1 on: June 07, 2010, 08:12:03 PM »
Just a technicality but "knock off" sounds a bit dodgy, the designs were actually licensed from SU. Parts are generally not interchangeable between British and Japanese though.
Might also be worth mentioning the differences in round tops as well, generally categorised as 3 or 4 screw (counting the screws holding down the "dome" lid)
More info here:
http://www.ztherapy.com/technical_stuff/spotterguides/zcar/240spotter.htm
1973 240z
1977 260z 2+2
1977 rusty clump of metal
Offline Scoota G
  • R.O.E.
  • Donating Member
  • Registered User
  • Mark
« Reply #2 on: June 08, 2010, 07:32:29 AM »
The Flat Top's are commonly referred to as "Boat Anchors"
Technology costs a money and a money we don't got.
Offline Rock Doc
  • Registered User
  • New Member
« Reply #3 on: October 18, 2010, 02:57:49 PM »
Hi guys, I am new to the forum and to my 260 z 2+2 '75.
My carbies seem to be flat tops but run round port not square ports on the intake from the air filter.  My understanding is that the flat tops have the square port intake (according to K&N) or did Australia get a halfway house carbie between the old round tops with the round port and the US' Smog flat tops with the square port?
Offline 1600dave
  • Registered User
« Reply #4 on: December 22, 2010, 05:07:41 PM »
There is a "halfway" carb - the smaller flat tops off later model 180B SSS's. They are only 38mm bore though, not really up to the job of supplying a 6 cylinder.
"Z" flat tops have the float chamber integrated into the carb, all other Hitachi SU's (including the 4 cylinder flat tops) have seperate float chambers off to the side of the carb.
Toecutter may not know who I am, but Lurch does !!
Offline Gordon Dobie
  • Registered User
  • New Member
    • Datsun Performance Centre
« Reply #5 on: June 15, 2011, 09:13:00 PM »
The 260Z SUs have had a lot of "bad press" mainly due to the fact that most mechanics don't understant the basic design pricipals or how to go about tuning them.
The first thing to check is the float level. A small window is provided in the front of each carbie for this purpose. The fuel should be level with the small dot in the centre of the window. If this is correct and assuming some "bush mechanic" has not been fiddling with the factory settings the carbs will do the job they where designed for. The fuel level is usualy too high due to worn neeldles and seats. Replacement of the needles and seats should bring the float level back to the original settings. Another possible cause of a high float level can be a sunken float. Solution, replace the float.
Gordon Dobie
« Last Edit: June 16, 2011, 01:06:06 AM by gav240z »
Offline gav240z
  • Gavin (Auszcar Webmaster)
  • Administrator
  • Registered User
    • Datsun 240z Project
« Reply #6 on: June 16, 2011, 01:07:11 AM »
Thanks Gordon, hope you don't mind but I edited your post to remove the large blue font from your post as it looked like you were an angry school kid shouting over the internet. ;).
1972 Datsun 240z
Offline NZeder
  • Registered User
    • http://nzeder.net
« Reply #7 on: June 16, 2011, 06:57:22 AM »
I too have heard that the 260z carbs are not a bad as many think and could actually be better depending on application/engine spec. Thanks for your input Gordon
76 RS30 260z 改RB26 N/A 霞
Previous
70 HS30-00016 240z
72 HS30 240z L型 2.8
71 HS30 240z L型改3.2
79 HS130 280zx
82 HS130 280zx T top
2x 73 KP710 160JSSS
74 KB210 120Y Coupe
71 510 1600 Deluxe
