Author Topic: 1971 240Z parts needed  (Read 261 times)
Offline acf321
  • Registered User
« on: February 08, 2010, 04:32:52 PM »
Hi all,
Still looking for;
1) luggage tie down straps for rear parcel shelf
2) round caps that fit onto the round seat adjuster knobs to hide the nut and bolt hidden beneath.
3) stainless trim the surrounds each of the rear taillights (that fixes onto the rear fascia panel)
4) little metal clips that are welded to the rear of the car directly beneath the rear tail light cut outs. These are used to hold the base of the rear fascia panel onto the car.
Adam
Offline NZeder
  • Registered User
    • http://nzeder.net
Re: 1971 240Z parts needed
« Reply #1 on: February 08, 2010, 05:35:51 PM »
You can get the luggage straps from here
http://www.zeddsaver.com/luggage_straps.html
or
http://www.zcarsource.com/content/p/9/catid/7840_8383/Luggage_Straps_70_78
or
http://www.datsunzparts.com/trim.htm
and then there is evilbay they turn up every now and then.
Also found another early-ish zed here in NZ that was missing the luggage straps so maybe they were an option on the early cars and standard later? Only if there was more info on that :(
« Last Edit: February 08, 2010, 05:43:21 PM by NZeder »
76 RS30 260z 改RB26 N/A 霞
Previous
70 HS30-00016 240z
72 HS30 240z L型 2.8
71 HS30 240z L型改3.2
79 HS130 280zx
82 HS130 280zx T top
2x 73 KP710 160JSSS
74 KB210 120Y Coupe
71 510 1600 Deluxe
Offline Gareth. J.
  • Donating Member
  • Registered User
« Reply #2 on: February 08, 2010, 06:16:18 PM »
I have a 73 240z with luggage straps, they were in very poor condition so i took the to a automotive appolsterer. $30... Bargain, and actually very useful!
