Author Topic: Peter T's 75 2+2  (Read 19441 times)
Offline sexual_sushi
  • Donating Member
  • Registered User
    • 26TZD Ownership history (WIP)
Re: Peter T's 75 2+2
« Reply #45 on: March 06, 2010, 12:23:42 PM »
Hey mate what's the rust like on those guards? I might take them if it isn't to bad. I've got a new aftermarket fuel pump I could trade ;)
Also what did you replace the brake lines with? Did you just buy the tubing and bend it up yourself or did you get it from another car/supplier? I'm going to be doing this to my project car at some point, I was just planning on buying the tubing and bending it myself.
1973 240z
1977 260z 2+2
1977 rusty clump of metal
Offline peter t
  • Donating Member
  • Registered User
« Reply #46 on: March 06, 2010, 12:57:48 PM »
PM sent. Had the brake lines done at Springwood Brake and Clutch. They rekitted  front and rear cylinders and supplied new masters for brake and clutch as well as rebuilding brake booster at a resonable price.
Cheers,
         Peter "T"
  75 260Z 2+2
Offline Sirpent
  • Donating Member
  • Registered User
  • John.O.
    • Sirpent Zed
« Reply #47 on: March 06, 2010, 01:32:01 PM »
Well I finally decided to respray the bus before all the new interior goes in. Started to rub her down and waiting for new front guards to turn up. The old ones have the headlight pods welded on and need some minor repair so I am sticking with original looks as have two spare sets of pods to go on. Old guards are up for grabs if any one wants them cheap. Not sure how far back I should go with the rub down so any comments will be greatfully accepted also hints on do don't does on resprays. God I love working on the Z. Gets me out of a lot work around the house.
Hi Pete,
Once again a personal thanks for all the effort with the extractors you shipped across...........
The paint, I noticed that the rub throughs on the areas you have sanded back seem yellowish, is that correct?
If so this would indicate the car has been done before as the original undercoat layers would have been a white/bone color.
If this is the case, then that would mean the color layers you are rubbing back are 2K / Enamel most likely low baked.
The only dangers you face with spraying straight over the top are as follows.
(A) If you are going to apply a 2K over the top again, you may see shrinkage that outlines the actual shape of the rub through areas some months down the track, to avoid this you would be best to apply a sealer coat of high fill over those area's first, I also know there is what is called an ISOLATOR undercoat specifically designed for this exact purpose, what ever you do, dont apply a wet coat of acrylic primer over it, the acrylic thinners may actually cause a reaction if applied to wet either at the time of application or after the final 2K top coats are applied.
(B) If you are planning to paint it in acrylic, the same applies as in the previous point, you ca easily fry the rub through edges if you are not carefull, and what must be remembered is that enamel is like concrete, while acrylic is a much sofet material, after a period of time, the 2 having reacted differently to climatic conditions of hot and cold weather work against each other and the the upper surface starts to disply stress in the form of crows feet, blistering peeling etc etc etc.
(C) If that is hi-fill under the upper coats, then I would actually use the color coat as a guide coat and block it all back until you have more or less a hi-fill surface again, this will have the effect of flattening out the panels to a glass smooth straight finish, minimise the material you have on the high fill and greatly reduce the defects mentioned in the last 2 points from occuring.
Personally, I would go with option (C) and then send the car around to a bpaint shop and have them spray and bake a new enamel finish on.
John
RS30 #005067 Restoration
"Das Drehkraftmonster RS32 AMG"
Full pictorial at
http://www.facebook.com/sirpentz
Offline peter t
  • Donating Member
  • Registered User
« Reply #48 on: March 06, 2010, 02:02:03 PM »
John,
       Glad you are happy with the extactors, The car has been redone quite a few years ago and the yellow under coat is K&K primer filler. I have resprayed the engine bay and inside door, boot lid areas already with K&H acyrlic paint and clear top coat and had no problems. I am only going to do the same with the rest as can't afford the 8 to 14K I have been quoted for a respray from several body shops. I have done a Sunny for my daughter in this manner before and it turned out allright. The car won't see a lot of sunlight so I will keep my fingers crossed. Will do a small test area first but the areas I have done are OK. This car is not going to be a show car but a very good looking Sunday driver for and old fart and his missus. If I can convince her it is safe. Gave her quite a few frights in the old 1600 out in the bush many years ago. Thanks for your help but not being a pro painter it is hard to understand some of your comments. Thanks anyway.
Cheers,
         Peter "T"
  75 260Z 2+2
Offline peter t
  • Donating Member
  • Registered User
« Reply #49 on: March 11, 2010, 05:32:20 PM »
Well the new guards have arrived from All Z Parts and I must say Warren done a good job of packing them. All I need now is to fit and paint them. This is the daunting part for me and I am still looking for some one to help in this matter. All I can say is HELP. If you are in the south side of Bris and want to help a fellow Z car owner or want to make a few extra bucks send me a PM. Thanks.
Cheers,
         Peter "T"
  75 260Z 2+2
Offline WogsRus
  • Donating Member
  • Registered User
  • New Member
« Reply #50 on: March 11, 2010, 05:59:01 PM »
how much for new guards. Asking as i need two and probably better to get new then fix the ones i have
Offline peter t
  • Donating Member
  • Registered User
« Reply #51 on: March 12, 2010, 05:55:28 PM »
Got them from All Z Parts for $495.00 Each plus $110.00 Freight.
Cheers,
         Peter "T"
  75 260Z 2+2
Offline KatoKid
  • Donating Member
  • Registered User
  • Location: South Mexico.... where the low lifes cant find me.
  • New Member
« Reply #52 on: March 12, 2010, 06:47:16 PM »
Ditto for me, I could repair mine but if they are a good fit I would prefer to go new.
Does anyone know where Warren sources his from (Black Dragon or MSA etc) and how are they for quality and fit?
Husaberg...its half a KTM
My Project: http://www.viczcar.com/forum/index.php/topic,6400.0.html
71 240Z #000728
77 260Z 2+2 Gone but not forgotten.
2012 Husaberg 570FE....giddy up!
Offline peter t
  • Donating Member
  • Registered User
« Reply #53 on: March 13, 2010, 03:31:19 PM »
Guards were nissan parts. A few ripples on one guard but that is this how any new panels turn up. The usual gap fitting must be done but I am happy with what I got having seen new panels on other cars at the work shop. Shaun and Steve turned up today to pick up my old guards and it was great to have a chat with a couple of nice young fellows. Got rid of old guards and picked up a brand new petrol pump. Thanks Shaun.
Cheers,
         Peter "T"
  75 260Z 2+2
  • Donating Member
  • Registered User
« Reply #54 on: March 13, 2010, 04:42:12 PM »
And thank you for the guards. Good to have a chat, next time I'll have to bring some rum ;)
Good luck with the rebuild, you're doing some good quality work there. Those interior parts in particular looked pretty schmick :)
1973 240z
1977 260z 2+2
Offline peter t
  • Donating Member
  • Registered User
« Reply #55 on: March 19, 2010, 05:15:59 PM »
What a job, Have fitted new guards and light pods. Found the right hand side one had been filled with bog as it was very proud to the guard. Was just about to fill the guard with bog then decided to rub the pod and found heeps of bog. Check out the pics and now the gaps are great. All I have to do now is gap the doors and start to paint. This is going to be the most frighting part. Will let you know how it turns out.
Cheers,
         Peter "T"
  75 260Z 2+2
Offline reverendzed
  • Donating Member
  • Registered User
  • I'm Dave & Yes! I'm a real Revhead..er Reverend...
    • Rev's Zed
« Reply #56 on: March 19, 2010, 06:17:46 PM »
Well done Pete.  Just make sure you put some hi-fill on those guards and pods otherwise you will see those orbital marks in your finish coat.  Let me know if you're not sure on anything paint wise I would be glad to help with any info.
Rev.
For God so loved the world that he gave his one and only Son and Zed's!
Orange 260 http://www.viczcar.com/forum/index.php/topic,5550.0.html
Silver 260 http://www.revszed.synthasite.com
White 260 http://www.viczcar.com/forum/index.php/topic,3785.0.html
Offline peter t
  • Donating Member
  • Registered User
« Reply #57 on: March 19, 2010, 06:37:08 PM »
Thanks Rev. Picked up primer from MPA Refinish Supplies today and these guys are very helpfull in advising me what steps to take. They are only too helpfull in mixing the paint I want and will match it. They mainly do work for trade and are  also agent for POR 15. That is how I found them. The rest is up to me as a pro job is just out of reach of my budget. With the help from the guy up above it will tuirn out alright from a distance.
Troncy.
Cheers,
         Peter "T"
  75 260Z 2+2
Offline aristo93
  • Registered User
  • New Member
« Reply #58 on: April 01, 2010, 02:21:51 AM »
what coilovers did u use on the front and rear and were they a direct fit? what hub did u use aswell?
Offline peter t
  • Donating Member
  • Registered User
« Reply #59 on: April 02, 2010, 05:20:02 AM »
Nothing flash here mate. All is standard with new shocks etc.
Cheers,
         Peter "T"
  75 260Z 2+2
