Author Topic: Just won a Subaru 3.9 LSD :)  (Read 3651 times)
Offline MaygZ
  • Registered User
  • We all started somewhere. Where are you Lurch???
    • Build Thread
Re: Just won a Subaru 3.9 LSD :)
« Reply #15 on: March 12, 2010, 04:50:01 PM »
Those axle adapters are awesome.  The HybidZ thread is a very interesting read.
Does anyone know the ratio of a 1998 STi diff -
http://cgi.ebay.com.au/Subaru-Imprezza-STI-GC-1998-GEARBOX-REAR-DIFF-ASS_W0QQitemZ380207619161QQcmdZViewItemQQptZAU_Car_Parts_Accessories?hash=item588623dc59
Zeds are more fun than women!!   You know I'm right, but you're too scared to admit it!!
http://www.viczcar.com/forum/index.php/topic,7841.0.html
Offline .
  • Registered User
  • Past member
« Reply #16 on: March 13, 2010, 06:25:21 AM »
Generally 3.9
Offline Zedman240
  • Dimitri V
  • Donating Member
  • Registered User
  • 'I hate it when people spell my name rong'
« Reply #17 on: March 13, 2010, 06:54:37 AM »
That's the same seller who stocks R200 longnose LSD's from early Skylines etc.. Just send a question if you need one. Avg price was $990.
HS30-00121 'early girl' .........Me love zeds long time..
RS30-15224 'older girl" in progress!
Breaks - Something that fails.
Brakes - Stop your car.
There - in  or  at  that  place  ( opposed  to  here).
Their - of, belonging to, made by, or done by them
Online nat0_240_chevZ
  • Registered User
« Reply #18 on: March 18, 2010, 10:26:26 AM »
aaahh  not a bad score then , i dont think the cv shaft from a suby would hold up in a zed very long
Why??? plenty of overpowered rear wheel convverted STI's around.......
i think 500+hp sti's and and wrx's are a decent comparo??? remember the cv is inherantly strong torque transfer mechanism than a uni joint no?? aswell as more efficint without any speed variations/pulsing???, you would be suprised....
Offline .
  • Registered User
  • Past member
« Reply #19 on: March 18, 2010, 10:39:58 AM »
The standard subi stub axles are still the weakest point. They snap before any breakage of CVs unless modified stub axles are used. It will be interesting to see how our imported stub axles handle the Zed. I'm not too worried about mine as I do not have high HP. But then again it is torque that breaks them.
Offline MaygZ
  • Registered User
    • Build Thread
« Reply #20 on: March 18, 2010, 04:36:54 PM »
I may have missed something, but isn't the pupose of the adapters so that the original Zed halves can be used?
I've done a little research and 3.9 diffs are in the 01-06 STi's.  Before this they were 3.44 and after they were 3.54.
Gotitrex has the 3.9's for $750 (93180550).  That would mean a solid LSD for about $1500 with the US stubs.  A bit of $$ but from my research and understanding a good LSD will massively improve the handling of a tweaked Zed. (Prob more that $1500 into the engine)
Offline sexual_sushi
  • Donating Member
  • Registered User
    • 26TZD Ownership history (WIP)
« Reply #21 on: March 18, 2010, 05:41:28 PM »
The cv talk is in relation to my original plan. There is another guy on Hybrid who has adapted the subi cv's to fit in the rear of a z. These other 'adapters' from JohnC weren't available at the time. I still plan on doing the cv's in my 240z and using the adapters in my 2+
2 eventually. For the meantime, it will be going into my 240.
Also remember that a relatively 'bolt in' r200 lsd goes for around $1000. Sure you can get lucky and get one cheaper but it's not that common. I paid $300 for the subi lsd + $605 for the adapters so for $905 I've got a lsd that's lighter than the r200 (I assume) and only 9 years old max.
1973 240z
1977 260z 2+2
1977 rusty clump of metal
Offline MaygZ
  • Registered User
    • Build Thread
« Reply #22 on: March 18, 2010, 08:01:52 PM »
did you get your lsd off eBay?  great price.  I never thought I would have 'diff envy', but I do >:(
Offline .
  • Registered User
  • Past member
« Reply #23 on: March 21, 2010, 04:01:57 PM »
Well guys, I have mine setup and ready to go in the car. The stub axles fit well and look great. I did have to drill out the bolt holes ever so slightly to be 10.5 mm  This now matches the original bolts. Had a heck of a time getting the nut of the front flange. But I guess that is normal.
Once the shafts are in I can not move one side without the other side moving??? I thought it would move a bit if I used all my force but it doesn't budge. Is that normal?
On my Detroit locker one side moves freely until more force is applied then it locks. It will be interesting to feel the difference in the car. Although it will be hard to look past the difference in ratio (4.6 to 3.9)
Offline Zedman240
  • Dimitri V
  • Donating Member
  • Registered User
« Reply #24 on: March 21, 2010, 04:44:35 PM »
That's the break away pressure that is set in the LSD with shims. Some are set to around 50lb of pressure whereas others that are almost locked I think are near 200lb. The less you have the more slip and the more heat builds.
Offline kalium
« Reply #25 on: April 14, 2010, 12:32:00 PM »
After all that, I'd try the Subi halfshafts, if it's a R180 then most likely it's STI which are stronger. Hope this helps a little. I have a R160 subi LSD for sale if anyone wants one for there pedal car or Subaru??
Hmm, R160s  don't fit under a zed I'm guessing ?
Offline PZG302
  • Registered User
« Reply #26 on: April 14, 2010, 12:58:45 PM »
Should do, or easily made to as they were in 1600's and some 180B's from memory ;D
Offline Scando
  • Shane
  • Registered User
« Reply #27 on: April 19, 2010, 02:54:28 PM »
As long as they are long nose they should fit fine.
1973 240Z L28ET
Offline .
  • Registered User
  • Past member
« Reply #28 on: August 10, 2010, 03:18:07 PM »
Nooooooo!!! There is a Subi STI diff on Ebay and it is a 4.44 :D    but its in Japland :(    ah well I will keep looking.
