Author Topic: Intercooler on NA L28  (Read 2034 times)
Offline .
  • Registered User
  • Past member
« on: September 02, 2009, 06:26:36 PM »
Anyone got any opinions?
Of course you do. I mean anyone got any opinions whether adding an intercooler to an NA engine increases power? I guess the question is whether the drop in air temperature fully makes up for the added restriction to air flow. I guess thats why it works ok on turbos because the air is forced through?
Offline Zeddophile
  • I break stuff
  • Registered User
Re: Intercooler on NA L28
« Reply #1 on: September 02, 2009, 07:04:58 PM »
No point.  The intercooler works on a turbo because the turbo itself induces heat into the intake air as a byproduct of increasing its pressure, as well as from the housings themselves.
On a naturally aspirated car, all you'll do is give yourself a stupidly long intake tract, the bends in which will restrict flow.  I'll have to dig up the site I was on the other week, as it had some staggering figures on how much straight pipe one mandrel bend was equivalent to.  The intercooler will also pose a restriction due to its internal design.  Even on turbo cars, adding an intercooler where one wasn't before tends to give a pressure drop.
The equivalent of intercooling on an NA car is to feed in an efficient cold air duct which rams in air from the front of the car to the air filter.
Current:
'84 Range Rover, 4 inch lift, 4.6l V8, Megasquirt, Rear diff lock, 34' tyres.
'81 Alfetta GTV - 180rwhp 3.0 quadcam v6 w/GSX-R ITBs and Megasquirt.
'80 Alfetta GTV - Group S build in slow progress
RIP:
'76 260z 2 Seater
Offline nizm0zed
  • Alan
  • Donating Member
  • Registered User
  • 260z coupe in slow build
« Reply #2 on: September 02, 2009, 08:00:20 PM »
yea, just like that..... ;D
I am a man of cast iron, hot rubber and steam. Fire flows when I turn the key. The dragon moves at my command.
My build thread........
http://www.viczcar.com/forum/index.php/topic,2902.0.html
Offline Zedman240
  • Dimitri V
  • Donating Member
  • Registered User
« Reply #3 on: September 02, 2009, 08:19:42 PM »
Then just add one of those fake blow off valve speakers and the set will be complete! I think that will equal minus 10 Hp at least.
Brakes - Stop your car.
Offline Add
  • Registered User
« Reply #4 on: September 02, 2009, 08:23:30 PM »
So in other words its just a large cold air intake. IMO I think just a pod filter cold air intake would be better as it would force cold air in quicker. You could try it and provide feedback, results speak louder than misinformed opinions.
Live your life in such a way that when your feet hit the floor in the morning Satan shudders and says 'Oh s***, hes awake'. - MX
Offline mtopxsecret6
  • Registered User
« Reply #5 on: September 03, 2009, 02:58:48 AM »
ADD, how would a pod filter force air in over a flat panel filter? In an atmo engine, the intake will always be negative atmospheric pressure, the most it would be able to do would equal atmospheric pressure at full noise, the pod filter would create an equal amount of restriction as a flat panel, there's no gain to be had from flat to pod the two would have the same surface area as each other. In theory the front mount air filter would suck more cold air with a surface area of 16inch by 8.5inch, as opposed to a 2.5inch pipe as a feeder to a filter sitting in a hot engine bay in the first place. In theory it seems like it would work better.
Ive seen many track car with there pod filters hanging just below the front headlights in full flow of the air, for this same reason, full cooler air compared to the engine bay heat. They use a pod filter not because if flows better, but because it can suck air in a 360 degree direction, which a flat panel can't do, and would also be to big to setup as such as this.
If you were to go this far, you would cool your fuel with a little front mount cooler, to make the fuel more dense along with the air going into the combustion chamber. I have this setup on my 32.
You can buy spacer kits for inlet manifolds that cool the intake charge air that's supposed to work pretty well i here.
« Last Edit: September 03, 2009, 03:08:53 AM by mtopxsecret6 »
Offline RB30X
  • Donating Member
  • Registered User
« Reply #6 on: September 03, 2009, 07:12:54 AM »
With the holdens and LS1's, OTR's or over the radiator intakes were proven to increase quarter mile times due to the air being able to 'force' into the throttle body once the car was at speed. The actual surface area of the long skinny panel filter was approx half of the original panels surface area, so I could never understand how they improved performance so much......but still bought two.
By the way those pretend intercooler air filters are for transgender's with Excel's, to go with their electronic BOV's. Get a turbo so you can have an intercooler or stay away.
Offline Scando
  • Shane
  • Registered User
« Reply #7 on: September 03, 2009, 10:18:47 AM »
bahahaha.  That's gotta be up there in the greatest rice mods of all time  ;D
What about a pod filter at the front with the pipe back to the plenum going through a dry ice box?  It's highly dangerous and expensive for the results but would work  8)
1973 240Z L28ET
Offline RB30X
  • Donating Member
  • Registered User
« Reply #8 on: September 03, 2009, 12:03:49 PM »
It would be easy and make more power to just use nitrous to cool intake air. Either that or get one of those car fridges and plum your intake air through that.
Offline Zedman240
  • Dimitri V
  • Donating Member
  • Registered User
« Reply #9 on: September 03, 2009, 12:59:00 PM »
Nitrous is injetced into the cylinder because when it's burned, it creates oxygen which lets the petrol burn more efficientlyl; I've heard it called "chemical supercharging". I'm not sure if a very fine mist of water is sparyed near/on the intake air would cool it enough to make a difference..
Eh, just make sure your filter isn't around hot air and that should be enough!
Offline Add
  • Registered User
« Reply #10 on: September 03, 2009, 05:41:58 PM »
mtopxsecret6 read my last sentence that is my disclaimer.   ;)
Was just thinking of alot of air being forced down a pipe into whatever setup is (efi/carb) being used. My Bad!
Offline nizm0zed
  • Alan
  • Donating Member
  • Registered User
« Reply #11 on: September 03, 2009, 08:09:39 PM »
partially correct.
Oxygen is an oxidizer (who would have thought ;D) so you are right in saying that it allows the fuel to burn more efficiently.
However in an engine it also cools the air quite a lot, allowing it to be denser, and utilise more fuel with that denser air.
When you inject Nos, you also need to inject more fuel, to keep the proper ratio with the now denser air, but also because the extra oxygen released as the nos seperates will burn with the extra fuel.
end result, power.
And according to one movie, blue/green flames and self ejecting floor panels.
Offline RBZ 260
  • Johnny
  • Donating Member
  • Registered User
  • S chassis Nutter and 240z Hoarder
« Reply #12 on: September 04, 2009, 08:56:21 AM »
LOL i remember when that came out and one of the doosh bags i know started telling people that what happens when nos gets used blue flames at the back and ulike in some warp speed everythign goes blue infront of you.
i slaped him and told him to jump of a building for saying that as  he will do rest of us justice him not being around.
Galderdi what u been takin or talking to someone that has been taking some good stuff to come up with these wierd ideas lately   ;D
LOL 4stroke to 2 stroke and this  ;D
anyway not going to go into detials what happens its been said above
but to add to RB30X comment about raming air into LS1 for better pperformance is quite true and been around for last 35+ years.
Camaros, firebirds, mustangs corvettes etc.... all had this in the hot days of muscle car wars back in the mid 60s and early 70s. u win a race on sunday people buy it on monday.
they refered to as RAM Air and it proven to give approx 5mph and reduce the time by 0.25s on the 400m not bad for putting a hole in the bonnet and adding a scoop for fresh colder and somewhat forced air.Thats in a very "aerodynamic"  (NOT) 69 Mustang.
though that NA "intercooler" on civic (had to be civic) sure looks from a distance as an intercooler. that perpex cover with small holes kinda defeats the purpose of it... Im sure that cost a fair bit but u get lot better performance with a decent pod placed in the right location and lot of leftover dosh to spend on tune and better jungle juice to increase power.
none mentions fuel in increasing power... put some avgas or c16 and see how it goes than  ;D
RIP 76 260z 2+2 RB20DET
http://www.viczcar.com/member-rides/johnny-kostics-rb20det-datsun-260z-22
67 Mustang Coupe
70 S30 240z #227 Resto
72 S30 240z Unknown future
73 S30 240z RB26DETT project
97 S14a 200sx Luxury
98 ER34 GT-t Aero
01 S15 200sx Spec R
Offline Zedman240
  • Dimitri V
  • Donating Member
  • Registered User
« Reply #13 on: September 04, 2009, 01:20:18 PM »
From memory you can buy some of the exotic fuels like methanol, C16 etc from large fuel distributors. Theres one in Dandenong but haven't been there in years. I'm sure they are all over the country.
Offline waxhead
  • Registered User
« Reply #14 on: September 04, 2009, 02:17:13 PM »
C16 at about 4-5 dollars a litre would send you broke fast
Running avgas in your car is not a good idea
Its all about heavy tops so it doesnt flash off in plane wings
That means its hard to light it may be high octane but thats about it
You will not be making much more power out of it
