Author Topic: 4 stroke into 2 stroke  (Read 774 times)
Offline .
  • Registered User
  • Past member
« on: September 02, 2009, 05:53:18 PM »
I met a guy about a year ago who told me he has a Dihatsu Cherade. One of the old 3 cylinder jobs. He reakoned he had converted it from 4 stroke to 2 stroke and gained 50% power in the process. At the sacrfice of torque.
Anybody know if it is possible?
Obviously as a minimum it would take a very special cam and ignition setup. Imagine a 2 stroke zed :D
Offline Lurch
  • Locky
  • Global Moderator
  • Registered User
  • Oracle of BS.
Re: 4 stroke into 2 stroke
« Reply #1 on: September 02, 2009, 05:58:17 PM »
Man... there are some people out there who are so full of sh*t...
Offline Zedman240
  • Dimitri V
  • Donating Member
  • Registered User
« Reply #2 on: September 02, 2009, 08:13:25 PM »
I once met somebody who told me some old guy gave him a convertible E Type Jag...for nothing...when asked "where is it?"....."oh...I sold it!"... yeah okay..
Brakes - Stop your car.
Offline Scando
  • Shane
  • Registered User
« Reply #3 on: September 03, 2009, 10:36:44 AM »
hehe, 2 strokes don't have cams....  ;)
You would need to weld up the valve holes in the head and bore ports on either side of each cylinder for the inlet and exhaust to go through.  Then you would have to put sleeves from the outside of the block to the cylinder sleeve to make your ports, ignition would be easy.  Then after all your hard work you'd find out it's no good because the L6 crank viabrates everything to peices before it pulls enough revs for a 2 stroke to make decent power........
Did some old Charade's come with a 2-storke option?  I know daihatsu made some 2 stroke vans  :)
1973 240Z L28ET
Offline waxhead
  • Registered User
« Reply #4 on: September 03, 2009, 06:13:54 PM »
No its not possible
Offline NZeder
  • Registered User
    • http://nzeder.net
« Reply #5 on: September 04, 2009, 03:18:06 AM »
No its not possible
So you are using a double negative so then that makes it possible؟
it is possible but it does involve a complete engine replacement - out with the 4 stroker and in with a 2 stroke that is designed and build as a 2 stroke from the get go؟.....sorry just being sarcastic
« Last Edit: September 04, 2009, 03:19:38 AM by NZeder »
76 RS30 260z 改RB26 N/A 霞
Previous
70 HS30-00016 240z
72 HS30 240z L型 2.8
71 HS30 240z L型改3.2
79 HS130 280zx
82 HS130 280zx T top
2x 73 KP710 160JSSS
74 KB210 120Y Coupe
71 510 1600 Deluxe
Offline waxhead
  • Registered User
« Reply #6 on: September 04, 2009, 04:37:44 AM »
That wasnt the question
The question is can you turn the 4stroke into a two stroke
the answer is "No its not possible"
what did you want me to say " Yes its not possible"???
Offline Zedman240
  • Dimitri V
  • Donating Member
  • Registered User
« Reply #7 on: September 04, 2009, 06:33:14 AM »
I think Mike was saying it should be "No, it's impossible". The "No" in front of the "not possible" is how can you say it..cancelling the "not" out?
Offline waxhead
  • Registered User
« Reply #8 on: September 04, 2009, 07:00:46 AM »
wow
Im almost to scared to talk on the forum now. "impossible , not possible" always thought they meant the same thing.
Offline NZeder
  • Registered User
    • http://nzeder.net
« Reply #9 on: September 04, 2009, 03:25:47 PM »
wow
lol they do in that context - remember this is the English Language we are talking about and writting like "No its not possible" is a double negative so that has the affect of changing the meaning to be "it is possible" got to love the english language. As Zedman240 pointed out it is more technically correct to state
"No, it's impossible" and even "No, it's not possible" works but "no its not possible" does not due to missing punctuation = double negative, I believe the second one works as the comma make the No and Not appear in different clauses so there is no double negative.
Hell and I failed English + I am a Kiwi and I know how you ozzies love to take the piss (read with a kiwi ascent) about how we speak. From your "Friend in the Fridge"  ;D or for those younger TV viewer "Beached as Bro"  (have not been to Oz for almost 12months so not sure about any new ads) :'(
« Last Edit: September 04, 2009, 06:01:55 PM by NZeder »
Previous
70 HS30-00016 240z
72 HS30 240z L型 2.8
71 HS30 240z L型改3.2
79 HS130 280zx
2x 73 KP710 160JSSS
74 KB210 120Y Coupe
71 510 1600 Deluxe
Offline waxhead
  • Registered User
« Reply #10 on: September 04, 2009, 03:35:36 PM »
"No, it's impossible" and even "No, it's not possible" works but "no its not possible" does not due to missing punctuation = double negative, I believe the second on works as the comma make the No and Not appear in different clauses so there is no double negative.
Actually I am a Kiwi as well
You guys must have fun prove reading people posts on the web. I'm sure there is endless fun out there
Offline maddos
  • Donating Member
  • Registered User
« Reply #11 on: September 04, 2009, 04:35:27 PM »
Look out mate they're gonna start on you for not writing "proof reading" now.
More contraversy...... ::)
1/75 260 2+2
Offline Zedman240
  • Dimitri V
  • Donating Member
  • Registered User
« Reply #12 on: September 04, 2009, 04:42:19 PM »
All this is about being clear and easy to understand. There may  be thousands of people who will be reading through this thread and the last thing we want is a thread or forum that doesn't make any sense.
I'm sure the English lesson is over now...
Offline maddos
  • Donating Member
  • Registered User
« Reply #13 on: September 04, 2009, 04:56:33 PM »
I think you're all full of ****. Read ok to me.
1/75 260 2+2
Offline Zedman240
  • Dimitri V
  • Donating Member
  • Registered User
« Reply #14 on: September 04, 2009, 05:16:39 PM »
I hope this doesn't turn into something like those 3D posters that have that hidden image....some can see it straight away, and others take some time ...FFS, can we just let it die?
