Author Topic: Rev's new Zed Project  (Read 24149 times)
Offline Lightmaster240z
  • Donating Member
  • Registered User
  • Now total Master of the lighting world
Re: Rev's new Zed Project
« Reply #75 on: January 21, 2010, 07:37:48 PM »
Sorry big fella but mt car love coming to visit you  :'( :'(
regrads
bruce
The man to see for your lighting neededs
Offline MaygZ
  • Registered User
  • We all started somewhere. Where are you Lurch???
    • Build Thread
« Reply #76 on: January 21, 2010, 08:53:01 PM »
Looking good Rev.
The good Lord certainly gave you some skills.
Zeds are more fun than women!!   You know I'm right, but you're too scared to admit it!!
http://www.viczcar.com/forum/index.php/topic,7841.0.html
Offline luvemfast
  • Simon
  • Donating Member
  • Registered User
« Reply #77 on: January 22, 2010, 05:06:51 AM »
I haven't touched mine for 6 months now :(
Taken a vowel of celibacy Lurch?
Offline gav240z
  • Gavin (Auszcar Webmaster)
  • Administrator
  • Registered User
    • Datsun 240z Project
« Reply #78 on: January 22, 2010, 06:15:00 AM »
Touche! How did I miss that opportunity to poke the bear? :)
1972 Datsun 240z
Offline Lurch
  • Locky
  • Global Moderator
  • Registered User
  • Oracle of BS.
« Reply #79 on: January 22, 2010, 07:34:47 AM »
Ahh shiver! Touche Simon! Well done hahaha...
Offline reverendzed
  • Donating Member
  • Registered User
  • I'm Dave & Yes! I'm a real Revhead..er Reverend...
    • Rev's Zed
« Reply #80 on: February 01, 2010, 07:01:51 PM »
This is a 'no pic' update for now.  I've been hearing Serpent tell stories of his polyester primer etc so always willing to learn and experiment went out and got some polyester high fill and....WOW  :o  This stuff is awesome! it's a 2 pac application where you lay down about 4 double header coats with about 5 minutes flash off in between, I left it overnight and then begun to sand.  The finish is like nothing I've ever used, it fills the imperfections and comes out smooth as!  I've just found a new best friend!  Can't wait to prime and topcoat BUT lots of knocking back of the high fill first :-\
Rev.
For God so loved the world that he gave his one and only Son and Zed's!
Orange 260 http://www.viczcar.com/forum/index.php/topic,5550.0.html
Silver 260 http://www.revszed.synthasite.com
White 260 http://www.viczcar.com/forum/index.php/topic,3785.0.html
Offline Sirpent
  • Donating Member
  • Registered User
  • John.O.
    • Sirpent Zed
« Reply #81 on: February 01, 2010, 07:41:26 PM »
Rev, you stole my thunder !
DAMN you...........LMAO
Glad someone else took the plunge also, but please tell me you knocked back dry block and not wet? and I have to ask what brand ?
John
RS30 #005067 Restoration
"Das Drehkraftmonster RS32 AMG"
Full pictorial at
http://www.facebook.com/sirpentz
Offline zzzzed
  • mick the zed freek
  • Registered User
« Reply #82 on: February 01, 2010, 08:33:30 PM »
we use it all the time at work im sure its PPG
meh
240z in the making
Offline reverendzed
  • Donating Member
  • Registered User
    • Rev's Zed
« Reply #83 on: February 21, 2010, 04:34:27 PM »
Thought that it was time for an update.  I underestimated the time I would need to spend on the Ol' fashioned 'hammer & dolly' work on the guards I think I probably spent about 10 hours per side and probably 5 hours per side on the doors! But after almost giving up I'm happy with the result.  Just got engine bay left to do and inspection flaps and I'm ready for a bit more Polyester high fill, run back, prime and topcoat...not long now.  Also got the rubber on the new wheels and it looks ok!
Rev.
« Last Edit: February 21, 2010, 04:36:38 PM by reverendzed »
Offline reverendzed
  • Donating Member
  • Registered User
    • Rev's Zed
« Reply #84 on: February 21, 2010, 04:35:58 PM »
a few more
Offline Sirpent
  • Donating Member
  • Registered User
  • John.O.
    • Sirpent Zed
« Reply #85 on: February 21, 2010, 05:43:55 PM »
Looking SHMICK Rev !
Full pictorial at
Offline gav240z
  • Administrator
  • Registered User
« Reply #86 on: February 24, 2010, 04:59:34 AM »
Looking the goods Rev, what colour are you going to go with on this 1? Or is it secret for now?
1972 Datsun 240z
Offline reverendzed
  • Donating Member
  • Registered User
    • Rev's Zed
« Reply #87 on: February 24, 2010, 06:27:16 AM »
Hey Gav, I'm still undecided to some degree, choices right now is Omaha Orange, Octane Orange or a red/orange.
Rev.
Offline reverendzed
  • Donating Member
  • Registered User
    • Rev's Zed
« Reply #88 on: March 02, 2010, 05:46:54 PM »
Well I had some fun on the weekend, went to fit up the headlight buckets onlt to find that like most Zeds there was uneven gaps between the fender and the cone...so I came up with an idea that worked fantastic.  I thought I would post some pics in case anyone else encountered the same problem.
What I did first was to make a template out of thick card that would protrude about 2cm around the guard and bucket, I then bolted it together and applied body filler up to the card on both sides.  When this had hardened well I then did a rough sand to remove most of the excess filler.  I then removed the bucket from the fender, removed the card (carefully) and then reattached the bucket.  Then using a hand flat sander made sure that I sanded accross the fender and bucket to make sure they were even.  Separate the bucket again and sand a small chanfer (beveled edge connecting two surfaces) on the bucket and guard.  Prime both surfaces and reattach...and presto perfect gaps with factory appearance.
Offline reverendzed
  • Donating Member
  • Registered User
    • Rev's Zed
« Reply #89 on: March 02, 2010, 05:49:10 PM »
and PRESTO!
