I decided to go one step further than our sleeve kit and adapt an HSD TT-type coilover to my 240Z. This took a bit of mixing and matching, but the end result gives me a larger range of height adjustment and a large-diameter 12-step adjustable damper.
First I had to pick a suitable damper. Based on the overall body length and stroke I chose this TT damper from the front of a GC8 WRX kit.
To adapt this to the 240Z strut tube we used a base bracket from an EK Civic, which we machined down to match the inside diameter of the strut tube.
The standard strut tube was then cut down to only 50mm long, so we could slide in the bracket and weld it in place. For extra strength two holes were drilled in the tubes so we could weld onto the lower part of the bracket too.
