Author Topic: Tutorial: Door Skin Removal for Dummies.  (Read 6011 times)
Offline Reaper-Zed
  • Registered User
  • Lance
Re: Tutorial: Door Skin Removal for Dummies.
« Reply #15 on: August 31, 2009, 11:09:52 PM »
I have a feeling I might need to do this myself..... I'm glad you have posted this Lurch.
Has anyone bought a new door skin from rare spares??? I'm considering doing it for the drivers door seeming its got a fair few stress lines in the metal, might see how a hammer and dolly goes bit trial and error not exactly experienced in metal panel beating / shaping but really keen on learning if people have some good tips that be great
2002 Lancer daily driver
CB250 Sunday Bike Ride
1976 LX Torana SL project
1972 Datsun 240Z project
Offline Lightmaster240z
  • Donating Member
  • Registered User
  • Now total Master of the lighting world
« Reply #16 on: November 26, 2009, 02:47:37 PM »
 I Just got one from rare spares yesterday. It is going to DR Z{Lurch} work shop soon. I keep you informed as to how it go's
regrads
Bruce
PS are going to the BBQ ????????????
The man to see for your lighting neededs
Offline Scoota G
  • R.O.E.
  • Donating Member
  • Registered User
  • Mark
« Reply #17 on: May 19, 2010, 02:55:55 PM »
Any updates on the Rare Spares item ... i just got a set myself.
Technology costs a money and a money we don't got.
Offline Lurch
  • Locky
  • Global Moderator
  • Registered User
  • Oracle of BS.
« Reply #18 on: May 19, 2010, 03:52:36 PM »
They fit - but make sure to take your time fitting them.
The welds at the tops of the doors need to be good 'n' strong too before you start knocking the lips over.
I also found that annealing the lips on the door made them much easier to knock over ;)
Offline Zedsabbath
  • Donating Member
  • Registered User
  • New Member
« Reply #19 on: May 19, 2010, 05:07:46 PM »
So how did you anneal them Lurch, without spoiling the skins...I'll be re-skining mine some time in the future, got two Rare Spares skins here ready to go
Pete
A supplementary question : What to do with the old skins if they only have small rust holes ? toss em or hang on to them
Offline Lurch
  • Locky
  • Global Moderator
  • Registered User
  • Oracle of BS.
« Reply #20 on: May 19, 2010, 06:30:23 PM »
Firstly, I really shouldn't call it 'annealing them' - more softening them to make it more pliable when beaten over the door shell.
I take the lips back to bare metal, then lightly rub some liquid soap onto the lips then heat the area (with a Map Gas torch) till the soap goes black.
Then hammer away while they are still warm ;)
Secondly, if they only have a few holes in the old skins, I'd just repair them.
I'd only replace the skins if they are well & truly stuffed.
Thirdly, Pete please change your user-name as it's gotten quite silly now!
Offline MaygZ
  • Registered User
  • We all started somewhere. Where are you Lurch???
    • Build Thread
« Reply #21 on: May 19, 2010, 08:38:10 PM »
From the papsmear himself??
Lurch,
My door skins look just like yours did before you replaced the skins.  Is that the best/only way to fix them or is it possible/feasible to cut and replace the bottom couple of inches?
MaygZ
Zeds are more fun than women!!   You know I'm right, but you're too scared to admit it!!
http://www.viczcar.com/forum/index.php/topic,7841.0.html
Offline Zedsabbath
  • Donating Member
  • Registered User
  • New Member
« Reply #22 on: May 20, 2010, 01:38:44 PM »
Thanks for that tip Lurch...I guess the thing to avoid is overheating the metal so it doesn't distort the skin, I'll be very careful and sparing with the heat...I think annealing is a good idea, even standard practice too I think among professionals
Actually my old skins or at least one of them has had the treatment that MaygZ just talked about, replaced bottom 3 inches...but probably done without removing skin first, rego job most likely, heaps of bog to finish off
So to answer MaygZ's question, remove skin first for the best job....if you learn how to fuse weld with an oxy you'll save yourself a lot of heartache...and of course panel beating but yes it is very possible and feasible to replace that narrow bottom section, it's a dying art though, thankfully there's that show on TVS channel, forget what it's called now but lots of good tips on panel work
No worries there Lurch, you read my mind, gunna change my ID soon, already have one in mind, wait for it !........
Offline Bigfella
  • Donating Member
  • Registered User
  • Owner of rust
    • My Z Build page
« Reply #23 on: May 20, 2010, 02:35:12 PM »
http://mick-curson.blogspot.com/
I think these are the guys. Very interesting!
Offline Zedsabbath
  • Donating Member
  • Registered User
  • New Member
« Reply #24 on: May 20, 2010, 03:55:33 PM »
Gasolene that's the one
Offline Scoota G
  • R.O.E.
  • Donating Member
  • Registered User
  • Mark
« Reply #25 on: May 20, 2010, 05:33:10 PM »
"Guzzoline, pumps runnin day and night Ka Juunk, KaJuunK, KaJuunk, thousands of gallons. I couldnt get in there, Nooooo, but a man with your ingenuity"
Gee are we off thread topic or what... i'm gonna start a new one.
Offline nizm0zed
  • Alan
  • Donating Member
  • Registered User
  • 260z coupe in slow build
« Reply #26 on: February 21, 2011, 02:47:55 PM »
well, excellent writeup.
I just finished doing my drivers door skin.
Next time im out at the shops i'll grab some seam sealer and cavity wax and finish the job....
In case it wasnt answered before, Yes, the rare spares skins DO come with the reinforcing frame at the top of the panel.
They also appear to be heavier than the factory skins.
It wouldnt be much, but holding one in each hand you can feel the weight difference.
When i spoke to the bloke at rares, he made a bit of a deal about there being hardly any stock left.
It may just be an excuse as to why he took 2 weeks to order it thought....
I am a man of cast iron, hot rubber and steam. Fire flows when I turn the key. The dragon moves at my command.
My build thread........
http://www.viczcar.com/forum/index.php/topic,2902.0.html
