They have plenty of caliper clearance unless your calipers sit too close to the hub.As an example, an S13 with S14 brakes won't clear, but with larger GT-R size discs they will.
Hello Ben couple of questions. Ive bought the 17x9 and 17x 9.5 Rotos off you a while back. Where can i buy some nuts to suit and what size tyres would you recommned? I have kings lowered springs if it makes a diffrence.
We have forged aluminium wheel nuts to suit for $4.50 each.
Same problem I'm afraid. The clearance at 25mm is zero, but at 40mm out there is 50mm. In other words if your discs were one inch bigger you could fit anything.
Ben, would those aluminium wheel nuts fit Performance brand wheels also? I assume they are M12x1.25 pitch? thanks
How about the RB family? Any luck there?
Hopefully Ben will get some more of the 9 and 9.5 for my other car
