Whats everyones gut feeling for using 7" (205's) tryres on 8" rims for the front ?
Not sure if the stock tyre size/ rolling diameter for 240's and 260's are the same but 215/55/16 would be larger and put your speedo out, 225/50 or 205/55 is closer to stock.
You should be able to get michelins and pirelli's in 215/55/16.
My opinion only, I am not too fond of Falkens
I am running 205/55/16's on 8'rim 0 offset, no problem. I know some tyre manufacturers state 7.5" as max for a 205. I took the advice of the tyre shop manager, he said it is not a problem-didn't blink an eyelid. Although he did advise against 205's for a 8.5".
If it makes you feel better, 8" = 203.2mm
