Author Topic: WTB: datsun fairlady 2000 sr311  (Read 3246 times)
Offline Lynton
  • Donating Member
  • Registered User
Re: WTB: datsun fairlady 2000 sr311
« Reply #15 on: January 28, 2012, 06:50:27 PM »
Their rarity and originality will reign supreme, post purchase and mechanically modifying the car, while personally might be nice thing, in this sort of car it won't cut it on resale. Lynton 8)
Offline Ben
  • Registered User
« Reply #16 on: January 28, 2012, 08:56:51 PM »
Not necessarily, but having an SR20 in a ladder frame chassis with wishbone suspension and front discs (but only if you get a 1600/2000) is a pretty brave move.
You wouldn't be the first to do it though. An atmo one from an S13 would do the trick nicely, but there are a few mods to be done to make things like the gearbox fit.
Ben
L28ET 1973 240Z
FJ20ET 1983 DR30 Skyline RS-X
RB25DET 1996 WGNC34 Stagea RSFV
1975 1200 ute for sale, $3500 w/A14, $2500 without
Offline dat2kman
  • Registered User
  • comin' down the mountain!
« Reply #17 on: January 28, 2012, 09:36:38 PM »
Thats exakerly what i'm intending.
Sr20det, water/air intercooler, s14 vvt motor, high mount stock s14 intake plenum, hi mount aftermarket exh manifold.
As its body on chassis, no issue with sectioning the firewall for exhaust clearance.
The chassis runs a cruciform centre, this needs cutting out, and re boxing to fit tje s14 5 speed, gearstick comes up through stock hole.
Diff is to be replaced with a common BW 78 from a R31 wagon, cut down, it retains stock rear disc with mech handbrake, more than adequate, when combined with a 284 mm diam front vented rotor, and four piston calipets that attach to stock mounts.
The double wishbone front end is plenty strong, no issue, Nissan over engineered it.
Rear ends in the later 2000's ran an upper torsion/anti axle wind up rod on rh side, a duplicate is done for lh side.
A few have been done in usa, their greatest isdue is the left hand drive setup fitting in with the brake masters, clutch master, and plumbing for turbo assy and exhaust, very busy.
Ive dummied up a s14 sr20 det into it, just need cutting and fabricating done.
Intention is to run stock steel wheels with original 2000 hubcaps, no bonnet scoops or outward signs of conversion, save for slightly larger exh pipe on exit.
Should be interesting.
I just race old datsuns:
Offline 260z.76
  • Registered User
  • New Member
Offline Ben
  • Registered User
« Reply #19 on: January 29, 2012, 06:17:45 AM »
Mad Performance here in Adelaide is doing an SR turbo conversion in a Fairlady as we speak.
Ben
L28ET 1973 240Z
Offline garvice
  • Registered User
    • GAS 260z RB26ET
« Reply #20 on: January 29, 2012, 08:54:40 AM »
Sounds like a nice project jason. I javed been thinking about these with a turbo sr20 for a few years. The misses has dropped the occasional line that she would like a car and I reckon one of these would be good for her, should be easy to work on.
Offline Zbitz
  • Registered User
    • Zbitz
« Reply #21 on: January 30, 2012, 10:41:13 AM »
I have a 1970 2000 for sale  paul@zbitz.com.au
Offline datsfreak
  • Registered User
« Reply #22 on: January 30, 2012, 05:13:26 PM »
If i went the sr20 route would the standard u20 head and gearbox sell for much?
Its a ramdom question but does rechroming cost much(bumpers etc)?
zedless :(
Offline Ben
  • Registered User
« Reply #23 on: January 30, 2012, 06:06:30 PM »
Expect to spend about $1000 per bumper to get them restored to a professional finish.
Ben
L28ET 1973 240Z
Offline 1600dave
  • Registered User
« Reply #24 on: January 30, 2012, 07:09:20 PM »
I bought a Fairlady 5 speed a year or so back for $300, thought that was cheap but then again I wouldn't have paid much more as its easy enough to adapt an L-series 5 speed to the U20. A purist may disagree on the use of the L-series box, but my car is going to be modified anyway as its missing other critical aprts that mean a concourse, dead original restoration is too hard / expensive.
U20 head, might get a bit for it ? Depends if you can find a buyer.  It won't fit on a H20 bottom end (well, it will physically, but there is much more needed to get it working - a U20 crank for instance) so it is a limitied market. U20 crank is longer than H20, and has different number of flywheel boltholes.
Stainless steel repro bumpers can be had from Harrington http://www.groupharrington.com/en/part/37/datsun-fairlady-roadster-bumpers.html.
Toecutter may not know who I am, but Lurch does !!
Offline dat2kman
  • Registered User
« Reply #25 on: January 30, 2012, 08:07:37 PM »
I'm one of the silly ones that has to stick to a U20 engine in the Historic race car, so, if anyone hears of, or knows of engines either complete or in pieces, please let me know via pm on here.
Rules say I have to run it, and most who convert go to FJ, L or SR, or a more common but cheaper "period" style a H20 from an Urvan or a old Datsun forklift.
Thanks lads!
Offline datsfreak
  • Registered User
« Reply #26 on: January 31, 2012, 07:13:26 PM »
Thanks for the comments guys
Jeez , i had no idea rechroming was so expensive
thanks dave for that link- its great to see there is repo bumpers for these
« Last Edit: January 31, 2012, 07:18:08 PM by datsfreak »
zedless :(
Offline Mr Camouflage
  • must stop buying z's with sunroofs
  • Registered User
  • www.wazcars.com
    • www.wazcars.com
« Reply #27 on: January 31, 2012, 08:25:44 PM »
Thread idea!!! The Datsun's I'd own if I had the space.
ALL OF THEM!!! Well, one of each. Collect the whole set!!  ;D
www.nostalgictrio.com
'65 Silvia CSP311 #340 & #342
'70 & 72 240Z
'73 240K Hardtop & 77 Sedan
'84 300ZX <-- For Sale
'88 Skyline GTS-X (Daily)
'01 Prius (Soon-to-be Daily)
Sold:
Z31 Turbo, Super 6, 240Z, 77 Celica, 808 coupe, TX3 4WD
