OK,
Have all the details in a file at work, but what I can tell you is this
The ones I got were RDA Directionally Slotted Brake Rotors, and from memory the diameter was around 272-273 mm and 20mm thickness.
The stud pattern was spot on to the Z PCD of 114.3mm, but the centre hub seat had to be machined to the Z hub size.
Otherwise perfect fit.
Lurch will know the technical details better than I can recall, but I will post all the details of the applicable RDA part number, price, retailer and actual dimensions in the morning.
John
