Author Topic: Nizm0zed's coupe  (Read 16148 times)
Offline nizm0zed
  • Alan
  • Donating Member
  • Registered User
  • 260z coupe in slow build
Nizm0zed's coupe
« on: August 27, 2008, 04:52:17 PM »
ok, well, here it is.
dont expect updates often, im pretty slow when it actually comes to doing anything to my cars.
I bought my zed in july 07, heard about it through a friend, so i went and looked at it before the old owner was going to put it on the classifieds.
he was asking $1000 for it, and to be honest i was expecting a rust eaten s*&^#er.
Once i got there, i found out it was a coupe, not a 2+2 like i was expecting.
he explained that it was very hard to start, and the starter was stuffed, so it took lots of push starting, and that he thought it had a blown head gasket.
It also had some acco damage in one rear quarter, and lots of carpark dents over the doors.
I haggled and dropped him to $800.
had he have known what he actually had, he could have made $3000 easy within a week.
I caught a bus all the way across town to pick up my new toy, and met up with my bro once i took delivery of it.
We drove back to my place, and he was quite amazed that a 30yr old car would pull away from his VZ commo.
So was i to be honest.
I took pics of it that night.
once i got a chance in the daylight i went over it and had a real good look.
the biggest patch of rust i found was on the side of the RH headlight, in the front nose section, just behind where the bonnet hinge bolts on, Its about the size of my hand, so that'll need fixing asap, but everywhere else is just little bits, prolly no bigger than 4-5cm, im cheerin.
I also found a CD walkman under the passenger seat, SCORE!!!!!
the diff was redone not so long ago, still got a workshop sticker on it, no leaks from the engine or driveline, just a minor seepage from the sump gasket.
the exhaust looked alright, but needed modding, its a one piece system from the extractors right back to the tip, with only one resonator in it. It failed rego, but jeez it sounds hot.
as for my starter motor dilemma, i discovered that a starter form a RB30 will bolt in, good thing i had a couple of spares. the battery was shot, so a spare went in.
my to do before rego list is:
New windscreen
LH door window reg (mine sorta works)
LH door handle busted
rust in the RH headlight frame
couple of light globes
Cover the rust in the hatch (its on the inside)
mod the exhaust, too loud and hits on the diff cradle
So, after that, i went and got an inspection done.
It failed.
the exhaust is too loud. 115dB (5dB quieter than a helicopter  8) )
Play in the front tailshaft uni joint, easy job to fix, and a busted door handle, which i expected.
So, i swapped the door handles over either side, put a muffler in the system, and greased the uni's
then went and regoed it.
I used it as a daily for about 6 months, until i blew up the motor.
I had heard about the oil pressure gauges being temperamental after 30+ years, and didnt really think aything of the fact that mine barely even registered, until after about 3 monts of nil pressure, one of the crank bearings finally went.
tough motors ;D
Now, i have a 2.8L for it, a big turbo, and Injection, so im doing a rebuild.
first up came stripping off the front end, and repairing the rusty patch in the headlight frame.
I was very pleased to find minimal surface rust under the guards.
I sold off the metal panels, as i have aquired some fibreglass ones from Alfa Motorsports.
i have allready made a nice weight saving on that one.
i have a FG rear hatch and spolier on the way as i type, been looking for FG doors and headlight buckets, but no luck yet, unless i want to spend a small fortune.
I have painted under the guards with sound deadener, which will also help prevent any rust buildup.
last night i got into it after work, and started cutting things out of the bay, and smooting of the wire tabs.
damn, now im going to have to hide the wiring, shame huh  :)
the engine being built.
the head is at the shop getting done, should be back soon.
once its back, i have a genuine Nismo 0.6mm MLS head gasket and an ARP head stud kit to hold it all down.
My BIG turbo, just fits under the manifold in the stock spot.
My as of yet, un touched interior.
White vinyl and blue velour from factory.
more to come later......
I am a man of cast iron, hot rubber and steam. Fire flows when I turn the key. The dragon moves at my command.
My build thread........
http://www.viczcar.com/forum/index.php/topic,2902.0.html
Offline Neuby
  • Neuby
  • Registered User
  • Special needs civil engineer.....
    • My Youtube channel
Re: Nizm0zed's coupe
« Reply #1 on: August 27, 2008, 05:00:32 PM »
Fark! That hairdryer is huge!  Your bumpers look reasonably unscathed and straight too!  Good buy!
What is the yellow thing with flared guards in primer in the background?
1971 240Z #629 3.0L stroked and webered
DENAUS Motorsport
Offline chris240
  • Donating Member
  • Registered User
  • When in doubt...mumble.
« Reply #2 on: August 27, 2008, 05:05:09 PM »
$800 !!!! ...unreal.
Scott told me about this car, great buy.
who's doing your head work ? are you going to do most of the works yourself or give it out locally ?
HS30-010-2904
& 1980 Apollo III 12 speed....
Offline nizm0zed
  • Alan
  • Donating Member
  • Registered User
« Reply #3 on: August 27, 2008, 05:06:17 PM »
that yellow thing with flared guards in the background is my other coupe.
A Gemini with a CA18 in it, and getting some serious panel reworking done.
yea, too many toys ;D ;D ;D
the head is being done by phillip head services, i know them and i know they do good work.
i do pretty much every thing else myself
Offline Lurch
  • Locky
  • Global Moderator
  • Registered User
  • Oracle of BS.
« Reply #4 on: August 27, 2008, 05:31:20 PM »
Looks good Nizmo.
What are the specs on the turbo? It's obviously T3 based...
Offline nizm0zed
  • Alan
  • Donating Member
  • Registered User
« Reply #5 on: August 27, 2008, 06:37:33 PM »
turbo is a garret GT3271R.
should give a nice little shove in the back 8)
Offline sco_aus
  • Donating Member
  • Registered User
  • Scott
« Reply #6 on: August 28, 2008, 06:35:55 AM »
Sweet.  Can't wait to see it running.  Looks like us Canberrans are already nearly out numbering Vic, whats going on Vic, population uber, Zed enthusiasts, bugger all anymore.
Offline Lurch
  • Locky
  • Global Moderator
  • Registered User
  • Oracle of BS.
« Reply #7 on: August 28, 2008, 04:15:42 PM »
What? Just because I moved interstate means the Vic Zed population goes downhill? ??? :P
I reckon there are more Zeds in Vic than any other state...
/Puts flame suit on.
Offline Zedman240
  • Dimitri V
  • Donating Member
  • Registered User
« Reply #8 on: August 28, 2008, 05:12:49 PM »
I know in Vic there's one that's been in a garage for the last 3 MONTHS! Dammit! Sorry...just a little frustrated!
Brakes - Stop your car.
Offline Scando
  • Shane
  • Registered User
« Reply #9 on: August 28, 2008, 05:17:48 PM »
Wow!  That's gotta be bargain of the century.
Should be a real weapon when you get it finished.
« Last Edit: August 29, 2008, 07:01:28 PM by Scando »
1973 240Z L28ET
Offline nizm0zed
  • Alan
  • Donating Member
  • Registered User
« Reply #10 on: September 02, 2008, 06:30:11 PM »
woooo, progress  ;D
Offline nizm0zed
  • Alan
  • Donating Member
  • Registered User
« Reply #11 on: September 04, 2008, 05:12:23 PM »
Offline Neuby
  • Neuby
  • Registered User
« Reply #12 on: September 08, 2008, 03:22:09 PM »
Shiiiiiite!  Looking good!  Any anticipated figures from your engine build or just generally "fast"?
DENAUS Motorsport
Offline nizm0zed
  • Alan
  • Donating Member
  • Registered User
« Reply #13 on: September 15, 2008, 12:27:27 PM »
Neuby, time will tell as to what sort of power it puts out, its only a 'mild' build, as i don't really want to spend a fortune on the motor, seeing as i will more than likely end up changing it anyway.
I bogged on my car today ;D
Sanding will come later, hopefully tomorrow, unless i get carried away doing something else.
And my rocker cover is all shiny too.
was a pain in the ass, some previous person had put clear coat on it, and it was all flaky and crap, so lots of sanding, by hand, all the way down to 2000 grit paper, then polish by machine, then finish by hand.
There are still a few blemishes, but I'm happy with it.
so far the current plan is to head to the metal shop tomorrow, and get a bunch of stainless cap screws, just to help finish it off.
Offline nizm0zed
  • Alan
  • Donating Member
  • Registered User
« Reply #14 on: September 21, 2008, 05:40:19 PM »
well, had some decent progress.
i was planning on just spraying around things, like the steering column and brake lines,
But it turned out easier just to remove them to be done with.
I sanded back all the bog, cut out some more 'obsolete' wire tabs and mounting points, and put down a coat of primer filler.
that'll get sanded back nice and smooth, then i'll drop down a new coat of primer, and add some colour.
then i can start putting things back in 8)
ive been thinking about the brake master cylinder too, seeing as i need a 1 inch master, i figure i may as well use one that has the proportioning valve built in to it, and tidy up the lines a bit too.
adapting it to the booster will be incredibly easy.
Im planning on running the passenger front brake line along the back side of the crossmember, to keep it out of site.
