Author Topic: Datsun Camshafts & Valve Timing - A MUST READ!  (Read 7397 times)
Offline Gordon Dobie
  • Registered User
  • New Member
    • Datsun Performance Centre
Re: Datsun Camshafts & Valve Timing - A MUST READ!
« Reply #15 on: June 17, 2011, 02:10:25 PM »
Removal of the cam towers will not cause a problem. A common cause of the camshaft binding in the cam towers is a warped head due to a blown head gasket. If the head is surface ground on the gasket surface it is essential that the top surface is also machined or the cam towers will be out of alignment. Alliteratively appropriate thickness shims can be placed under the towers to bring them back into alignment.
If the head is bent more than .005" it should be straightened to within .005" prior to machining.
Gordon Dobie
Datun Racing Team Chief Engineer (Retired)
Offline dazzed
  • Registered User
« Reply #16 on: July 05, 2011, 01:10:54 PM »
Gordon Dobie
thats right gordo ,and if you do mix them, wack em on a flat bed and stick a straight edge through the middle of them all, if it rocks tis not good.  ps  this is a very old topic tisnt it
