Author Topic: Datsun Camshafts & Valve Timing - A MUST READ!  (Read 7397 times)
Offline Lurch
  • Locky
  • Global Moderator
  • Registered User
  • Oracle of BS.
« on: July 22, 2008, 06:50:44 PM »
Guys,
This is a MUST READ topic for ANYONE interested in selecting a performance camshaft for their L series engine.
Baz from Datsport was kindly given permission to reprint this on his website for all us fortune people!
It does go through the basics at first, but I found it refreshing to re-read it all again.
I suggest you only read it a few chapters at a time to let the info sink in...
Enjoy ;)
http://www.datsport.com/racer-brown.html
« Last Edit: October 09, 2009, 03:44:19 PM by Lurch »
Offline Cdr Zero
  • Akio Asakura
  • Donating Member
  • Registered User
Re: Datsun Camshafts & Valve Timing - A MUST READ!
« Reply #1 on: July 22, 2008, 08:01:55 PM »
Wow!  Fantastic resource, bookmarked!  Thankyou for sharing!  :)
HS30103643
Offline modular9
  • Donating Member
  • Registered User
    • Modular9
« Reply #2 on: July 23, 2008, 06:13:21 AM »
perfect timing and great resource. thanks for the heads up.  :)
These cars are so much fun.
Offline gav240z
  • Gavin (Auszcar Webmaster)
  • Administrator
  • Registered User
    • Datsun 240z Project
« Reply #3 on: June 09, 2009, 06:04:17 AM »
Quote
It is an ABSOLUTE NO-NO to remove the cam towers from the cylinder head because it is nearly impossible to restore correct cam bearing bore alignment after they have been removed.
I have heard this before also. I think its important to point out. I've seen a couple of members recently showed pics of engine heads with no cam towers on them.
Can anyone else verify this?
1972 Datsun 240z
Offline sexual_sushi
  • Donating Member
  • Registered User
    • 26TZD Ownership history (WIP)
« Reply #4 on: June 09, 2009, 06:37:02 AM »
Quote
I have been watching Ztherapy's tuning videos and he also mentions not removing the cam towers for the reasons mentioned above
1973 240z
1977 260z 2+2
1977 rusty clump of metal
Offline Scoota G
  • R.O.E.
  • Donating Member
  • Registered User
  • Mark
« Reply #5 on: June 10, 2009, 01:24:15 PM »
So what about when you shave the head and shim the cam towers?
Technology costs a money and a money we don't got.
Offline Lurch
  • Locky
  • Global Moderator
  • Registered User
  • Oracle of BS.
« Reply #6 on: June 10, 2009, 02:25:53 PM »
It's an old wives tale - If you torque the head down in sequence & check the cam isn't binding, it'll be fine :)
Offline 2+2er
  • Registered User
  • the start - 260Z 2+2
« Reply #7 on: June 10, 2009, 06:49:47 PM »
I did some time in an engine reco shop and there can be problems with the cam binding if the head has been over heated and the towers are not re installed in the same order.
Always mark each tower and base with a centre punch before you remove them and you should be fine, however it was good practice to only remove the towers when absolutely necessary.
Shims are mainly used to maintain the timing (distance) between the cam and crankshaft. An adjustable cam timing gear will do a similar thing only better.
Offline hunterzed
  • Registered User
  • Steve
« Reply #8 on: October 09, 2009, 04:41:19 AM »
The link isn't working for me. Has it been taken down?
1980 280zx stock
1982 280zx in rebuild
Offline luvemfast
  • Simon
  • Donating Member
  • Registered User
« Reply #9 on: October 09, 2009, 05:11:19 AM »
Used to work, I hope someone saved the file.
I was going to read it when I was closer to an engine rebuild.
Offline gav240z
  • Administrator
  • Registered User
« Reply #10 on: October 09, 2009, 05:37:32 AM »
Archive.org baby!
http://web.archive.org/web/20080721214115/http://www.datsport.com/Racer_Brown_Menu.html
If that doesn't work for you, let me know
1972 Datsun 240z
Offline Ben
  • Registered User
« Reply #11 on: October 09, 2009, 09:44:32 AM »
A true Datsun fan would have the original text handy (How To Modify...), and ideally a first edition.
Ben
L28ET 1973 240Z
FJ20ET 1983 DR30 Skyline RS-X
RB25DET 1996 WGNC34 Stagea RSFV
1975 1200 ute for sale, $3500 w/A14, $2500 without
Offline hunterzed
  • Registered User
  • Steve
« Reply #12 on: October 09, 2009, 01:46:56 PM »
Hey!!!! I resemble that remark.  ::) ;D
1980 280zx stock
Offline Lurch
  • Locky
  • Global Moderator
  • Registered User
  • Oracle of BS.
« Reply #13 on: October 09, 2009, 03:46:08 PM »
Jeez you guys are hopeless...!
Barry has redesigned his site - the racer brown article is still there:
Offline jamo240
  • Registered User
  • New Member
« Reply #14 on: February 25, 2011, 08:28:17 PM »
I Know this is an old post, but I thought I'd add to what Lurch said about cam tower changes.
It absolutely is an old wives tale that you can't do it! I took the towers off my early 240 head and put them on a late model N42 head so I could retain the spray bar oiling system....therefore not only did i take the towers off, i put them on a different head!
There was never a wiff of a problem....I just kept turning the cam as I torqued the head down, and no problem emerged, and when the bolts were all done up it turned just fine and then I put the rockers back in, and it's been going for many years now with no issues.
