Another small update, I've just carpeted the interior. The carpet is all unbacked grey stuff like you see on speaker boxes. It weighs almost nothing and you can stretch it easily so it's great for curved surfaces like the wheel arches. I made up new rear panels on either side behind the towers from 3mm MDF, plus a new panel over the tail lights from 6mm MDF. Everywhere else the carpet is glued directly to the painted steel floor. All of the bits that are still visible in white will be painted satin black this week. I don't plan to re-fit the original console, so I carpeted the depression in the tunnel where the choke lever used to sit. This makes a handy place to store bits and pieces. You may notice I also had the door trims retrimmed in black vinyl with dark grey center sections.
I'm still waiting on some custom-made induction rams for my injection before I can fit everything, but that should be my next post.
