Insert Quote
well they look sweet, your almost there if the car starts and idles. Did you buy this setup brandnew or secondhand. What sort of $ are we looking at here if you dont mind me asking
I bought these used from an Italian fella that sell them on e-bay. All up the set up has cost me about $1100.00 to date that is with carbs, manifold, linkage kit, soft mounts, trumpets. However, from my understanding you can spend that much quite easily on proper dyno tuning once installed.
Hi Sulio,
Congradulations on the latest edition to your car. Remember that Dellortos like about 2.5 psi fuel pressure. You can also change the bango fitting on the last carb to allow fuel to return to the tank through a small restriction , to reduce pressure on the needle and seats when the engine is turned off.
Thanks David, Yer well I have them running from the mechanical pump. I've noticed some time ago I also have a fueflow sensor inline between the pump and carbs. I do not believe it's a factory item so most likely remove it.
It regards to the small fitting I noticed it and I've plugged the reurn line. I'll look up the Italian fella for that lst fitting.
sulio ; You didnt talk about the sound i mean the ... Grrrrr sound.
Yer they do sound pretty good. Scare small children away!
Thestrutt bar clear easily as the carbs sit lower than the SU's.
Cheers,
Sulio
