Have both - The L26 and L28 share the same crank/rods. The difference is the bore and pistons (well the block is different too) but you could always do what others have done before (I know of 2 that have done this). That is have one of your L26 blocks sonic tested to see if they can take a 3mm overbore (Nissan state any of the L6 series can take 2mm without sonic testing - however do to age of the block sonic testing any 2+mm is recommended if used for racing - however for a road car you should be fine but best you find a good engine builder and get their advice as I work in IT and no nothing of rebuilding an engine so this is just info I either know or have read in books)
So L26 block with a 3mm over bore = L28 spec ie 79mm stroke, 86mm bore and 130.3mm rods is another option however not the cheapest and this is one of the reason some say get a L28.
Now with that said - there is in the UK? A 240z or 260z 2 seater? (I can't recall) but it has a L26 block with a 2mm overbore = good and save the very very rare Nissan FIA rally LY hemi head, triple carbs (not sure of the cam etc) but the engine put out 270HP (I assume a lot and I mean a lot of this is from the that rare head). From the reading and talking to people who build engines for a living the problem with the 240z/260z/280zx engines is the heads (not really a problem) what I am trying to say is performance gains come from the head first then any extra cc for the big HP.
If you zed is a road car and you are happy with your stock L26 performance then why not just do a fresh'n up (depends on the buget) balance, and some head work then stick on some triple 40's (45's would be too large for a L26 with mild work for a road car + the 40's will give better MPG for a road car) + 40's are cheaper to purchase
with a good cam for this setup your car will go very well - won't be the fast zed on the track but it will be fun to drive on the road.
