Author Topic: My 1977 260Z 2 seater, RB25DET converted (lots of pics, be warned)  (Read 21376 times)
Offline sco_aus
  • Donating Member
  • Registered User
  • Scott
Re: My 1977 260Z 2 seater (lots of pics, be warned)
« Reply #75 on: April 22, 2009, 04:40:38 PM »
Thats encouraging, though I think you have bigger brakes than me.
Offline Scando
  • Shane
  • Registered User
« Reply #76 on: April 23, 2009, 06:41:06 AM »
Yeah, the 15/16 one would probably do for your setup but I'd say if you're going to change it anyway then go for the 1".  At least you know that's sorted then if you want to go for bigger brakes in the future.
1973 240Z L28ET
Offline sco_aus
  • Donating Member
  • Registered User
  • Scott
« Reply #77 on: August 27, 2009, 11:11:42 AM »
Better update this.
Not much has been done really.  I have mostly fixed my brakes, but in the process have got a leak in my brake booster, so a new/reco one will be next.
I need money to get anything else done, I am hoping to get a fair amount of money some time in the next few months, so here is hoping.
Unfortunately my tax return had to go to my landcruiser since its my "daily", but i get a lot out of it so its worth it.
Whats left:
The surge tank has a crack in it, so that needs replacing.
The rear left side of the sway bar is not connected as the link seems to have gone missing....  So a custom will need making.
It currently would be struggling to push 100rwkw on the road tune it has, so a full tune is definately in order.  I am going to have a max tune of 260rwkw, i dont want to stress the motor, cos frankly, its more than enough power.
Last thing will be a full roll cage, but that depends on how much money i get, so here is hoping:  Rev can you say a prayer for me :D
Scott
« Last Edit: August 27, 2009, 11:13:44 AM by sco_aus »
Offline RB30X
  • Donating Member
  • Registered User
« Reply #78 on: August 27, 2009, 12:49:51 PM »
Where did you get a 1" MC?
Offline sco_aus
  • Donating Member
  • Registered User
  • Scott
« Reply #79 on: August 27, 2009, 12:51:32 PM »
I got 2 through a mate, but stupidly helped 2 other people out thinking i could get another one and now cant get one, so im using the 15/16th atm.  It will be fine for now.
Offline RB30X
  • Donating Member
  • Registered User
« Reply #80 on: August 27, 2009, 03:47:18 PM »
VL Turbo's are 1" from memory.
Offline Lurch
  • Locky
  • Global Moderator
  • Registered User
  • Oracle of BS.
« Reply #81 on: August 27, 2009, 04:54:32 PM »
Oi you twat!
I offered to lend you the $$$ to buy one at the time, when you got the 1" M/C's for Steve & myself, but you didn't want a bar of it.
It's your own bloody fault!!!
Offline V8Datto
  • Registered User
« Reply #82 on: August 27, 2009, 07:31:07 PM »
I have one of them, have not idear if I can use it or not
Early HS30
If you didn't build it, it's not yours
Offline sco_aus
  • Donating Member
  • Registered User
  • Scott
« Reply #83 on: August 27, 2009, 09:21:49 PM »
Oi you twat!
bbzzzzzzz, hook line and sinker. hehe  I was joking mate, you need it more than I
Offline Lurch
  • Locky
  • Global Moderator
  • Registered User
  • Oracle of BS.
« Reply #84 on: August 28, 2009, 08:06:49 PM »
*grumbles*
Offline Scando
  • Shane
  • Registered User
« Reply #85 on: August 29, 2009, 12:00:02 PM »
Put any more thought into what sort of cage you're going to go for when the time comes Scott?
The one you want is for a Patrol.  Should be able to get them from Repco, Bursons, etc.
1973 240Z L28ET
Offline NZeder
  • Registered User
    • http://nzeder.net
« Reply #86 on: August 29, 2009, 12:39:56 PM »
I got the patrol one recently here in NZ from Repco JB1419 - here is a link to a thread on this site with info and a pic
http://www.viczcar.com/forum/index.php/topic,3910.msg33735.html#msg33735
76 RS30 260z 改RB26 N/A 霞
Previous
70 HS30-00016 240z
72 HS30 240z L型 2.8
71 HS30 240z L型改3.2
79 HS130 280zx
82 HS130 280zx T top
2x 73 KP710 160JSSS
74 KB210 120Y Coupe
71 510 1600 Deluxe
Offline sco_aus
  • Donating Member
  • Registered User
  • Scott
« Reply #87 on: August 29, 2009, 03:39:41 PM »
Thats the one...
Cage:  No, not really.  Since there hasn't been any money and its the most expensive part, ill wait till the time then chat to some local CAMS cage builders.  Since the rules change every week, i'd rather wait till i have the funds.
Offline sco_aus
  • Donating Member
  • Registered User
  • Scott
« Reply #88 on: March 17, 2010, 07:01:00 AM »
So this what the Zed looks like.  This was taken where I picked it up, i'm stoked with the outcome.
Offline sco_aus
  • Donating Member
  • Registered User
  • Scott
« Reply #89 on: July 18, 2010, 10:14:38 AM »
Another quick update:
So I had to remove my exhaust manifold and get it re welded in a couple of spots from cracks.  Thanks to Dingo for that.
Also, today I have finished wiring up 2x battery isolators.  The first one is in the engine bay using the ground cable as the isolation and the second I have mounted in the spot where the heater etc controls used to be using the positive that controls the computer and accessories, the cables were already there left by the guy who re wired the car, so I could set up the isolator.  I have re made the the panel I used to have there with alumniclad and also used a carbon fibre looking panel that has an inbuilt isolator, start button and 4x rocket switches.  Its mostly show, but handy none the less, also it makes it look a little more professional and since it has inbuilt warning lights, definately will come in hand:
Next is to put the exhaust manifold back on, tighten and lock wire the Wolf creek CVs, re install the passenger seat and get it tuned.  Thats it, I will be really happy with it then.  Gotta have it ready for my wedding in November...
