Simon's 1976 260
I bought this car about 10 years agoindex.php?action=dlattach;topic=13383.0;attach=38098;image
It has an L28 with very early motec on it.  I started the car 2 days ago for the first time in 8+ years and I had fogotten how good it sounds.
Next step is to get a tailshaft made or found and check the tune.  Hopefully club rego some time in 2015 and catch up with some of you on a cruise or two!  Ill put up any pics, vids or progress that may be of interest.
Link to comment
Share on other sites
  • 3 weeks later...
  • 1 month later...
I bought the car as is, 10 years ago.  All I do know is that it has 50mm throttle bodies and early 2 Group Motec.  When I changed the gearbox I saw that it also has an ally flywheel and Sachs clutch.  It also has an external feed to the side of the oil pump and a big Harmonic balancer.    Internally,  I don't have a clue.    The head will have to come off soon to replace the gasket as it has a slight water weep out the side.  I'll know a bit more then.
Link to comment
  • 1 year later...
