TTT strut braces are US$120 each front and rear. Frt for lots of 5 is US$154.00 Sorry Stivva couldn't wait any longer. If anyone wants  these I will be ordering mine on Friday. Frt would be xtra from Brissie to you. You can look at them on the TTT web site. 8)
I see that MSA. Www.thezstore.com has very similar ones for the same price though they have grey attachments.  I am not particularly concerned with the colour.  Just want good quality at a reasonable price delivered yesterday!  ;D
Gabriel's gear is top notch and I am ordering mine Friday or you can order your own delivered to your door.  8)
Include a pair for me with your order and I will split delivery costs with you.
Alan
Done.
  • 6 months later...
Peter;
You mentioned during our recent drive to Toowoomba that you had to jack the strut towers apart to fit the braces.  How far did you have to move them for the rear brace?  Looks like I need to move them 10mm after i have removed the lock nuts and screwed the ends in completly.  I have attached some photos.  Will try putting the car up on the hoist to see if that helps to pull the strut towers apart.  May not be able to do this for a couple of weeks though as will be out of the country.  My car is a 74 2+2.  Would the distance between rear strut towers have changed in later yrs?
Thanks for your help.
Alan
Uh :o why don't they fit properly? I've had bars from Z spares in Sydney and my current Cusco bar. None of these had fitment problems and were all in the middle of adjustment range.
I would get the centre bar shortened and get the internal thread machined deeper, you may only have to cut/thread one side...
If you jack the body apart you are changing the angle of the struts and this will change the camber.
Peter;
Alan
Hi Alan, Mine were not that far out. I think now I only enlarged the hole for the bolt to fit through. will go and measure distance between towers now. ???
Hi, Measurement for S30 And GS30 between rear towers is 836.4 mm. ctr to ctr. Alan my car is spot on. I will check my e-mails to see if Gab can shine any light on your prob.
8)
Alan, can you e-mail me pics to send on to Gab at TTT. I have been trying to save and send pics from Auszcar but is beyond my it brain. I have already suggested he make these a little shorter and I am sure he will fix your problem. 8)
Peter
Measured my distance between towers and very similar to yours.  Definitely not 10mm difference.  Bar must be made too long.  Tried to put pics in message to you but couldn't get it to work.  Will need to email.  Off to Mongolia early tomorrow so will be out of touch for a couple of weeks.
Alan
