Author Topic: Can I use 17x8.5 without flares???  (Read 991 times)
Offline dat240z
  • Donating Member
  • Registered User
« on: June 23, 2012, 04:26:25 PM »
Hi, im getting a set of Rota RKRs and am hoping to see if anyone out there has a solid answer as to whether or not they will fit without scrubbing on my 71 240z.  i have coilovers which are 3 way adjustable (more room than stock) and currently run lotus performance 17x7.5 with 17/235/45 all round. Currently they sit about an inch in from the guards. Some people on hybridz reckon theyd be fine (17x8.5) with a +4 offset???
want to confirm before ordering from the states...
any help would be appreciated fellas
71 240z RB25det
Offline Agno
  • Alex
  • Registered User
Re: Can I use 17x8.5 without flares???
« Reply #1 on: June 23, 2012, 05:03:03 PM »
I run 15x8 -3 on the front of my car with a few degrees of camber (I forget how much) and they fit easy so you should be fine.
My car did used to scrub the castor rod at full lock with a big tyre when I used to have 15x7 +12 (equivalent to a 7.5 +6) on the front but for some reason nobody else seems to ever have this problem *shrug*.
Offline Zedman240®
  • Dimitri Vazz
  • Global Moderator
  • Registered User
« Reply #2 on: June 23, 2012, 05:09:58 PM »
I used to run some 17x8 Simmons with 225 tyres with lipped guards with coilovers and they did scrub slightly on some big heavy bumps. Forgot what offset they were but I do have the receipt somewhere with all the info.
HS30-00121 'early girl'
Brakes - Stop your car.
Offline d3c0y
  • Garage San Maru
  • Donating Member
  • Registered User
  • No, you can't fit 10" wheels without flares...
« Reply #3 on: June 25, 2012, 07:09:49 AM »
What offset are you running. I've made a Z wheel calculator in excel and I'll be able to tell you where they will sit.
Not putting miles on your Ferrari is like not having sex with your girlfriend so she'll be more desirable to her next boyfriend.
Engine: http://www.viczcar.com/forum/index.php/topic,10674.135.html
Car: http://www.facebook.com/pages/Garage-San-Maru/277779
Offline dat240z
  • Donating Member
  • Registered User
« Reply #4 on: June 25, 2012, 10:23:45 AM »
I was going for a +4 offset......
thanks mate
atm with 7inch wide on 235's (0 offset) it sits about 3/4 inch in  from guard...
71 240z RB25det
Offline sco_aus
  • Donating Member
  • Registered User
  • Scott
« Reply #5 on: June 26, 2012, 06:52:56 AM »
If it is driving, bring your zed around and we can fit my Rota RBs on your car
Offline d3c0y
  • Garage San Maru
  • Donating Member
  • Registered User
« Reply #6 on: June 26, 2012, 09:51:24 AM »
Dont you have 9J and 9.5J? I can tell you now they wont fit without flares as you probably know. What does that acheive?
Offline sco_aus
  • Donating Member
  • Registered User
  • Scott
« Reply #7 on: June 26, 2012, 09:52:43 AM »
Me?  I know what size wheels I have...
Offline d3c0y
  • Garage San Maru
  • Donating Member
  • Registered User
« Reply #8 on: June 26, 2012, 09:56:36 AM »
Havent had a chance to set up my home computer after moving house yet to get to the spreadsheet but this should answer your question:
http://forums.hybridz.org/index.php/topic/103675-rota-rb-r-17x85-4-offset-what-size-tires/
