Author Topic: Rear Strut Assembly  (Read 445 times)
Offline DTF260
  • Daryl
  • Registered User
  • 76' 260z 3.1L Stroker
Rear Strut Assembly
« on: January 27, 2012, 12:08:51 PM »
After a Strut assembly for the rear right hand side for my 260z to get it back on the road until i can afford to go down this track http://arizonazcar.com/strassy.html
Ive gone and bent the to arms that connect to the control arm... Heres a pic of what im after
Offline Zedman240
  • Dimitri V
  • Donating Member
  • Registered User
Re: Rear Strut Assembly
« Reply #1 on: January 27, 2012, 06:31:51 PM »
I have one here in Melbourne if you can't find one locally..
Brakes - Stop your car.
Offline DTF260
  • Daryl
  • Registered User
« Reply #2 on: January 27, 2012, 06:49:15 PM »
hmm, you wouldnt happen to know what the postage on it would  be would you?
Im after a sort of 'band-aid' fix on the cheap. Im hoping to upgrade to the the complete AZC setup when funds allow (in a month or two) and it would be nice to get it on the road for the rego thats due soon.
Offline Zedman240
  • Dimitri V
  • Donating Member
  • Registered User
« Reply #3 on: January 27, 2012, 06:58:04 PM »
I can probably send it with hunter xpress for about $20 to a business address. Weight would be around 10ish kg's?
Offline DTF260
  • Daryl
  • Registered User
« Reply #4 on: January 27, 2012, 07:14:39 PM »
sounds good, how much you after for the whole thing inc postage?
what do you mean business address?
Offline PeterAllen
  • Donating Member
  • Registered User
« Reply #5 on: January 27, 2012, 07:36:53 PM »
...Ive gone and bent the to arms that connect to the control arm...
Are you sure it's not the spindle that's the problem?
Offline Zedman240
  • Dimitri V
  • Donating Member
  • Registered User
« Reply #6 on: January 29, 2012, 08:16:40 PM »
If your zed is crab crawling, its the brackets in the pic below that have to be checked to make sure they are exactly 90'. If either or both are bent, they have to be replaced.
Item #5 in pic below.
Offline DTF260
  • Daryl
  • Registered User
« Reply #7 on: February 04, 2012, 08:36:13 AM »
Im positive the spindle is ok, the wheel was pushed from the outer rear edge and it seem it was the two arms on the strut assembly that gave up.
I had a look under the rear yesterday and it seems they brackets are still fine, although its tough to tell without replacing the obviously bent bit first.
Could I grab that assembly off you still Dimitri?
Offline Zedman240
  • Dimitri V
  • Donating Member
  • Registered User
« Reply #8 on: February 04, 2012, 07:29:31 PM »
No probz..I thought it was impossible to bend that strut casting for the rear axle.
Offline DTF260
  • Daryl
  • Registered User
« Reply #9 on: February 04, 2012, 08:28:08 PM »
Using the outer edge of the wheel to stop the car from 10 or so km/h seems to do the trick. i hope thats all thats been bent.
