Hey mates, So I just installed a 1979 Electronic dizzy from a 280zx with the E12-80 module on my early 74' 260z, and it's works Amazing.............The dizzy and car is awesome but the tach is my next dilemma.
Now I tried to google and searched all the forums, Zcar, hybridz, classiczcar, and I couldn't find an a diagram on how to make the 260's tach work.
Please let me know what I must do. So I have the following as info:
1. Green/White
2. Green/Red
These two wires were from the stock distributors pick up.
3. Blue wire which was on the negative on the coil (which I assume is the Tach signal?)
Now If I hook up the #3 blue wire, or one of the other #1 or #2 wires to the Negative of the coil, it does not start, or when it's running the car will die.
I hear that I have to use a 10K ohm resistor? But which wire? Where on the wire? and Where to hook it up to?
Can someone just draw me a crude picture on MS paint and let me see.
Here is my set up now. The Blue, Black/Blue, Green/White, Green Red, not used. Which one is tach and what must I do? Thank you.
