Well for the doubters of the $20k race car, here's the budget for all the build I plan, to get sub $20k I can leave a couple of things out.....
Shell - $1500
cage and seam welding - $5000
front cut with rear sub frame - $4500
Suspension - $2500
Brakes - $1000
Glass/perspex -$500
Wheels tyres (3sets) - $5000
Aftermarket computer and dash - $5000
Engine rebuild - $8000
Total budget - $33000 to have a winning car
To get on the track and be running faster than the Zed did at low 62's with the quickest being a high 61 at Lakeside, the follwing isn't required:
aftermarket computer and dash $5000
Wheels and tyres 2 sets $3500
A total saving of $16500
Giving a total budget to hit the track of $16500.
The basic order of build will be
1. finish shell prep for cage
2. get cage and seam welding complete
3. order half cut with rear subframe
4. get suspension and brakes and fit
5. fit motor gearbox and other ancilleries - wipers etc, from half cut
6. get wheels and 2nd hand slicks
7. have fun on the track
I am planning on building the car over the next 12 months, so I should be able to get everything I need inculding the nerd box and dash with the data logging I want, including GPS for timing, and the nice delta timing on the dash that is possible these days and seen in F1 and supertaxis. As well as procure a full set of spares for mechanicals and body, plus run 3 sets of wheels - 2 sets of slick being rotated through the car using a set per race meeting and a set of wets ready to go at any time, and maybe look at some slave wheels, ie very skinny space savers to push the car around on.
Whilst I don't have the fabrication skills for the cage and any major body work needed, I am a dab hand at wiring and can throw paint at a metal surface with a spray gun and get a resonable shine. Also a lot of the build is direct bolt on off the shelf bits, why reinvent the wheel when someone else has already done it.
This will be the fourth race car I have either built or been heavily involved with the build of, so I think I have a fair idea of what I'm doing and how to go about getting the best bang for my buck.
