The little tiny weeny, hard to see in a heated intense situation, red low pressure warning lamp buried down in the instrument cluster, goes off at around 8 to 10 psi of pressure, on start up.
In a lets say race stuation, you are cornaring and acceleratiing, the head valve train is full of oil, the sump is lowish, oil has shifted away from the pickup, you are concentrating on the view out the windscreen,,,,,, you wont see the little weeny tiny 8 psi low limit light flash on!
Fit a higher say 20 psi sender, a top of dash mounted hi intensity red led mini lamp, aimed at your eyes, youll crap yourself at how often it may flash.
Only thing NOT. To do is hang a T piece brass adaptor off side of block, to fit both senders, use a couple of push on hi press barb fittings, and hose, and remote mount the tee on inner guard, earth the tee!
Block harmonics can fracture the tee where it screws into the block, ,, think about all the weight of the two senders attached, same goes for those that use a tee for light sender switch, and oil pressure guage.
I have had two snap off at the pissy tiny 1/8 th npt thread where it goes into block.
