Author Topic: What are these electrical switches on 280ZX box?  (Read 772 times)
Offline wildy55
  • Donating Member
  • Registered User
« on: December 16, 2011, 09:31:24 AM »
Hi all, looking to find out what these three switches on my 280ZX box are. Using it in a 240Z so only need reverse switch.
Offline Six_Shooter
  • Registered User
  • Canuckian
Re: What are these electrical switches on 280ZX box?
« Reply #1 on: December 16, 2011, 02:09:46 PM »
The bottom one (in the picture is the reverse light, the middle one is 3rd or 4th gear switch (4th gear I'm pretty sure), the top one I'm not sure about, if it was nearer the shifter I would say a neutral switch.
Offline MaygZ
  • Registered User
  • We all started somewhere. Where are you Lurch???
    • Build Thread
« Reply #2 on: December 16, 2011, 03:38:06 PM »
Put a multi-tester on them and select the gears.  That will tell you which on is the reverse and which is the neutral/park switch.
I would suspect that, unless neutral and park are managed separately, that the third would go back to the ECU to tell it which gear you are in.
MaygZ
Zeds are more fun than women!!   You know I'm right, but you're too scared to admit it!!
http://www.viczcar.com/forum/index.php/topic,7841.0.html
Offline luvemfast
  • Simon
  • Donating Member
  • Registered User
« Reply #3 on: December 16, 2011, 06:33:27 PM »
I don't have any of those extra switches on my box.
Why would the ECU need to know what gear you're in?
Offline Gareth. J.
  • Donating Member
  • Registered User
« Reply #4 on: December 16, 2011, 06:55:29 PM »
The sensor with two black bullet terminals is a reverse switch  ;) the others I have no idea.
Offline dat2kman
  • Registered User
  • comin' down the mountain!
« Reply #5 on: December 16, 2011, 08:26:37 PM »
Upper two are somehow used to tell the ecu you are in a top gear, and adjust tje timing or fuel delivery for more economical running, mainly to do with USA emisdions, especially stricter California.
Aussie deliveted cars had no need for this, dunno wether the ecu "read" these.
I treid using them to send false signal in order to overfuel engine for race use, nup, it reduces fuel, and alters timing the wrong way.
I ended up using other sensors signals into ecu to get desired effect. Blew four up though, trying!!
I just race old datsuns:
Offline wildy55
  • Donating Member
  • Registered User
« Reply #6 on: December 17, 2011, 07:28:41 AM »
Cheers fellas!
Offline MaygZ
  • Registered User
    • Build Thread
« Reply #7 on: December 17, 2011, 01:53:44 PM »
What Jason said.
You just can't put a wise head on young, narrow, pretty shoulders   ;D
George
