Author Topic: 2-seater rear window glass variations question  (Read 907 times)
Offline gilltech
  • Registered User
« on: November 09, 2011, 03:59:18 AM »
I have two spare 2-seater original rear window glasses, identical in size, but noticeably different in thickness and weight. Just out of curiousity, is it simply a case of one being a 240 screen & the other a 260? Or was there a changeover at some other period in Zed history?
1974 260Z 2-seat
1967 Mustang fastback
Offline NZeder
  • Registered User
    • http://nzeder.net
Re: 2-seater rear window glass variations question
« Reply #1 on: November 09, 2011, 05:32:11 AM »
Depends on the market the donor car the glass came from in the first place.
260z stuff is as follows
General export = 4.0mm thick (ie NZ)
Europe export = 4.0mm thick
Australian export = 5.0mm thick
240z does not state other than
there a number of other part numbers for different markets, tint, temperd, heating but no mention of thickness so assume all 4.0mm thick.
76 RS30 260z 改RB26 N/A 霞
Previous
70 HS30-00016 240z
72 HS30 240z L型 2.8
71 HS30 240z L型改3.2
79 HS130 280zx
82 HS130 280zx T top
2x 73 KP710 160JSSS
74 KB210 120Y Coupe
71 510 1600 Deluxe
Offline nizm0zed
  • Alan
  • Donating Member
  • Registered User
  • 260z coupe in slow build
« Reply #2 on: November 09, 2011, 04:01:52 PM »
is this why it was REALLY hard to install my american market quarter window seals????
I am a man of cast iron, hot rubber and steam. Fire flows when I turn the key. The dragon moves at my command.
My build thread........
http://www.viczcar.com/forum/index.php/topic,2902.0.html
Offline NZeder
  • Registered User
    • http://nzeder.net
« Reply #3 on: November 09, 2011, 04:52:49 PM »
no that glass is the same thickness it is the hatch glass that comes in different thickness for the Australian market.
Previous
70 HS30-00016 240z
72 HS30 240z L型 2.8
71 HS30 240z L型改3.2
79 HS130 280zx
2x 73 KP710 160JSSS
74 KB210 120Y Coupe
71 510 1600 Deluxe
Offline gilltech
  • Registered User
« Reply #4 on: November 09, 2011, 08:58:10 PM »
You're right on the money NZeder, one screen is 4mm & the other 5mm. So the latter must be ex an Aussie delivered car, 25% thicker & heavier. Thanks for the clarification.
Do similar rules apply to the front screens?
1974 260Z 2-seat
Offline NZeder
  • Registered User
    • http://nzeder.net
« Reply #5 on: November 10, 2011, 07:24:50 AM »
OEM no all 6.0mm thick however I believe there is some aftermarket screens that are 7.0mm thick. Does that help John :D
Previous
70 HS30-00016 240z
72 HS30 240z L型 2.8
71 HS30 240z L型改3.2
79 HS130 280zx
2x 73 KP710 160JSSS
74 KB210 120Y Coupe
71 510 1600 Deluxe
Offline gilltech
  • Registered User
« Reply #6 on: November 10, 2011, 05:56:58 PM »
Thanks for the info. Interesting that Australia required a thicker rear screen. It may only be 25% but feels far more.
Sorry, but I have another question  ::):
Regarding glass tint (overall tint) - my NZ-delivered '74 260 has pale blue tinted glass; was that standard or an option? I've seen 260s that look to have clear glass, but then glass can be deceptive in certain lights. A forum thread some time ago indicated that only the very early 240s had clear glass & all the Zeds that followed had pale blue. But is that correct, or only correct for Australia?
« Last Edit: November 10, 2011, 06:11:45 PM by gilltech »
1974 260Z 2-seat
Offline mossy
  • Donating Member
  • Registered User
« Reply #7 on: May 07, 2012, 01:42:27 PM »
Can anyone clarify this last post as I have two sets of door glass and qtr window glass, one is clear and the other in a pale blue, not sure which to use on my 71 240z build
Offline NZeder
  • Registered User
    • http://nzeder.net
« Reply #8 on: May 07, 2012, 04:27:49 PM »
Again depends either were installed on the 240z default was clear tempered and option was tinted tempered.
So go for the look you want.
Previous
70 HS30-00016 240z
72 HS30 240z L型 2.8
71 HS30 240z L型改3.2
79 HS130 280zx
2x 73 KP710 160JSSS
74 KB210 120Y Coupe
71 510 1600 Deluxe
Offline mossy
  • Donating Member
  • Registered User
« Reply #9 on: May 07, 2012, 04:47:07 PM »
Thanks Mike, just had a look at my rear glass and realised out of the 4 I have they are all clear, might have to keep an eye out for a tinted one to match the side tinted glass.
