Author Topic: Z drift/time attack car  (Read 1161 times)
Offline Gareth. J.
  • Donating Member
  • Registered User
« on: October 16, 2011, 08:45:13 AM »
Cool looking drift/time attack Z  8)  I dont think it's the most beautiful ever but it's damn nice for a race car.....
http://www.driftworks.com/2011/04/is-this-the-most-beautiful-drift-car-ever/
Offline Scando
  • Shane
  • Registered User
Re: Z drift/time attack car
« Reply #1 on: October 16, 2011, 08:47:40 AM »
Very nice  :)
1973 240Z L28ET
Offline Z
  • Donating Member
  • Registered User
« Reply #2 on: October 16, 2011, 11:38:55 AM »
+1!
Offline FLEXZED
  • Donating Member
  • Registered User
  • Loui
« Reply #3 on: October 16, 2011, 11:47:29 AM »
love the front grill hmmmmm
LIFES JOURNEY IS NOT TO ARRIVE AT THE GRAVE
IN A WELL PRESERVED BODY,
BUT RATHER TO SLIDE IN SIDE WAYS, SHOUTING
“HOLY shiver WHAT A ZED  RIDE “
Project Journal: http://www.viczcar.com/forum/index.php/topic,5610.0.html
Offline chev z
  • Donating Member
  • Registered User
« Reply #4 on: October 16, 2011, 03:24:08 PM »
Incredible !!!
My 240 has a s13 rear end conversion with the rota 9.5x17's allround , using the Imsa widebody flared guards, coilover suspension with the willwood brake upgrade with wheel spacers .
The similarities are unbelievable
Except for the paint jobs, I really like theirs
" luv em ol' school " , 240 LS1 race project ,  datsun 260z 2+2
Offline DAZDA
  • DAtsun chassis - maZDA rotary engine
  • Registered User
  • Brap Brap Brap
« Reply #5 on: October 17, 2011, 09:57:13 AM »
Despite this,
Quote
"... you can guess how slammed Aardvark really is. In fact it’s 1175mm or 46“ tall, a full 4“ drop, done properly with redesigned geometry and Driftworks arms and coilovers all around."
the front splitter is still a long way off the ground???  Something doesn't look right to me.  Maybe the wheels are too big - the bigger the rolling diameter the higher the car is from the ground and you run out of room to lower the car more and fit the larger wheels in the wheel arches (even with flared guards)...
We use and recommend;
http://www.capitalsteering.com.au  - Steering you in the right direction
http://www.fifthgear.com.au  - Get the Driver's Edge
Offline chev z
  • Donating Member
  • Registered User
« Reply #6 on: October 17, 2011, 12:04:43 PM »
Totally agree about the splitter being to high .
I've just imported the IMSA splitter that goes with the wide body guards and they are aprox. 50mm wider, the only catch being that they are designed to incorporate the Gnose so extend way to far forwards ,so I will have to cut and join somehow.
Going the Gnose path was easier but more costly, saying that tho, I wanted to retain the original open front look which  complicates things but looks better to me.Each to his own I suppose.
Height wise .
He might need the extra height to enable the V6 to fit without cutting the sump or running a dry sump setup.When we fitted the LS1 we had to cut the sump by approx. 30mm and it's still the lowest part of the car.
Offline Gareth. J.
  • Donating Member
  • Registered User
« Reply #7 on: October 17, 2011, 04:42:53 PM »
There seems to be zero tyre to guard clearance, that could be the biggest problem. In the pics it's a bit hard to tell but it looks as if the front air dam isn't the same depth as the sil panels. I think it looks a few inches higher than the sills when side on. If you look at the door area it's fairly low, but from front on it's like a 4wd.
What is the grille made of?
Offline d3c0y
  • Garage San Maru
  • Donating Member
  • Registered User
« Reply #8 on: October 20, 2011, 05:08:46 PM »
 8) That's not a problem - it's the way it should be  8)
There is a build thread over on hybridz for this thing - it's insane!
Not putting miles on your Ferrari is like not having sex with your girlfriend so she'll be more desirable to her next boyfriend.
'73 240Z L24 44 Mikunis 5spd
'90 300ZX TT 2 Seater Targa 5spd
'01 Yamaha YZF-R6
'11 Kawasaki KX-F250 EFI
Offline Gareth. J.
  • Donating Member
  • Registered User
« Reply #9 on: October 20, 2011, 05:48:08 PM »
I'm feeling lazy, do you have the link  :D
Offline d3c0y
  • Garage San Maru
  • Donating Member
  • Registered User
'01 Yamaha YZF-R6
Offline Gareth. J.
  • Donating Member
  • Registered User
« Reply #11 on: October 25, 2011, 03:43:09 PM »
Whoops! I thought you already had the link, I've tried searching numerous things on hybridz and find it very time consuming to get what your looking for. Thanks anyway though  :)
